Magnaflow 14589 installed
This is my third muffler setup after stock, and I think I finally found the perfect one... Just thought I'd share. It's a 3" inlet 3" outlet, dumped before the axle, everything is stainless. Welded it up Sunday.
It sounds perfect. Idle is barely a murmur, cruising throttle around town you can hear it a bit more and it sounds good. WOT is as loud as I'd want it to be personally; it's not overbearingly loud, but you can definitely hear me coming!
Best part, no drone whatsoever. Normal highway speeds I can whisper and my girlfriend can still hear me. I can cruise at 70, 80, 90+ mph and hear everything no problem.
f5fb07f5aeb6c7ad9068bbf55988a55e.jpg6f3072ef8cab9c6ab3d88865f40aeb36.jpg0921a90fdc0030a7573a79913971bd7d.jpgaa922b82f2baa99bc5bdf0d6222dd1fe.jpg
Any chance of a video?
Definitely. I'll have one or two posted after work.
https://vimeo.com/158107538
I don't think the phone captured the full range of sound the muffler was emitting. All of the RPMs are actually accompanied with a deep tone. Cold start, then I let it idle down. Gave it a few revs (slight, mid, and full throttle) but I couldn't be too loud unfortunately. Any questions or suggestions for a better quality video, feel free to comment!
sounds very mild!!! i love it...... im curious though how is the resonance? if any! i would like this with a single exit tip though. i might be looking into this mod next!
Very mild indeed. When I called Magnaflow they claimed it to be the second or third quietest muffler they had.
I have zero resonance/drone in the cab at any cruising speed. At no point cruising or WOT has the sound been uncomfortable, it's great!
It's a single in, single out, straight through muffler.
I can't watch the video for some reason. Any ideas? Looks like a sick setup. Can't wait to hear it
Sent from my SM-G920T using Tapatalk
No clue. I uploaded it on Tapatalk. Maybe try to view it on the app?
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 840 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
