Tint Balancing question on LTZ
I scheduled my truck for tint and just need to figure out what % for back windows and back side windows. I don't believe there is any tint on my front side windows?
My toddler screams when the sun is in her eyes on trips. I am thinking 35% for the rear over the existing tint and 20% for the front side windows?
Sound about right? Or what do you recommend?
Thanks
5% over the factory tint? It must be blacked out. I need to still see a little. I haul trailers. the tint installer recommended 35% tint over factory. Stated that would equal 5% or so. Ideally, 15-20% for the back glass and rear doors is what I am looking for.
Back window is left alone and the sides are nicely blacked out. Stays nice and cool in the truck also. I tow also and have no issues.
I just had them do 20% in the top of the line 3M product and now all my windows match perfect.
I had my tint specialist remove the factory tint since it was basically non-existent and I didn't want to worry about bubbling...
He put on ceramic 5% on back and rear windows and 20% on the fronts - hard to see out the back but the rear-sliding option is wonderful at night.
Night & day difference with heat in the cab though.
I went with ceramic 35% in rear windows over factory tint and 25% on fronts. Also got 50% on my windshield and love the look!
Isn't the factory tint in the glass itself, not applied to it? [emoji848]
I left the back windows the factory percentage of 20 percent which is in the glass itself. I did 35 percent on the front two windows. It isn't black out but dark enough to keep the glare and inside cooler. I also don't have to worry about getting a ticket. Not sure what state you are in so I would recommend to check out your tint laws before you decide on a percentage.
If he charged you for this service(Removal), you've been taken...
Removal was free & came with lifetime warranty.
Executive MotorSports out of Houston did mine.
What did he remove?!
He actually removed the door panel, not the factory window shading...
Getting old, my memory fades :driving:
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
