I brought my new 16 SIerra into the dealer yesterday to take care of a few rattles. One in the upper dash around the windshield and another that seemed to be under or behind the steering column or gauges. They called me a few hours later and said both were fixed under an existing bulletin. They added insulation to under the trim piece along the dash where it meets the windshield and the same bulletin called for insulation against an inverter under the steering column area. I don't have the bulletin number with me right now.
I haven't heard the rattle under the steering column again yet but the dash one is still there - sounds different now but still there so I plan to take it back next week.
Anyone else have experience with these rattles?
I have a 15 Sierra sle, and it started making a rattling noise up by the left dash speaker. I have not taken it in yet as I'm afraid they will mess with it and make it worse. Prob have them look at it next oil change.
order some felt tape on amazon, and apply to the edges on your dash (the long piece that sits against the windshield and speaker covers), you'll have to remove the a pillar covers to get it out, but $12 and 35 minutes I was done. I'll try to find the pics on my phone.
I have this sound that sounds like a small rock chip hitting my windshield up where the dash and windshield meet occassionally. Like a lil cracking sound. I check my windshield every time and theres no actual crack.
(no its not actual rock chips hitting the windshield)
Ever find those pics?
Used tape like this? http://www.amazon.com/Yosoo-Universal-Flannel-Squeak-Adhesive/dp/B0169U1X7I/ref=sr_1_1?ie=UTF8&qid=1458302933&sr=8-1&keywords=automotive+felt+tape
10636779_10102644925096004_1999360128160
The small thin black is from the factory felt, the wider loooong strips are mine
12362805_10102644925091014_1391689140942
12371017_10102644925100994_5224628396311
Sorry it too so long, I had to search Facebook for them as I deleted them from my phone. I'm doing this from a work computer which is a no no, so I'll post link of tape later. Hope this helps
Thanks.
is that tape in the circled area too? are those tabs that insert into something? i haven't taken that piece off to investigate yet.
what about those metal clips i pointed to? those are the source of squeaking?
Was your rattle when just driving or due to the bass from the radio? I have a rattle due to the bass and it seems to be on the passenger side. I was trying to determine if these pictures might apply to my situation. I've had the rattle since day one of ownership and just can't deal with it anymore.
That sounds more like a bad or loose speaker. I would take it in. The dash speakers are supposed to be high passed so could it be coming from the door?
Edited by crewl1
I think mine is the plastic piece up by windshield. If I hold it it stops.
Thanks.
yes i wrapped the tabs, but used a screwdriver to open the clips. no more rattles.
To the guy asking about radios- it rattled regardless of radio operation.
Mine does the same thing, it drives me and my wife crazy. i cant seem to find the source, but it rattles when music is playing.
Another culprit is the daylight sensor (little half circle shaped that hooks up to the same piece)
Add some padding between that and the socket it goes in, good luck!
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 686 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
