Different gauge cluster backgrounds
Does anyone know if a company makes new backgrounds for our gauge clusters? I'd love to get a carbon fiber one to go with my truck being a Carbon Edition.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
