Rattling cab vents ?
Anybody else have Ringo Starr behind their rear seat ? My cab vents rattle like crazy when it´s windy outside & there´re driving me crazy . What´s the fix ?
Is that the same thing as the plastic piece or whatever between the cab and bed? Always rattles when I close one of the rear doors. I don't really notice a rattle when driving though.
Yes sir .
Now that you've mentioned it, I occasionally can hear it rattling when going over bumps in the road, really have to have the radio really low to hear it.
I just had my truck at the dealer for a sun visor squeak and rear headliner rattle. They fixed that, it was soooo quiet in my truck (well, minus the key fob hitting the steering column), and now you've got me hearing this noise :-(
Does it sound like a metal rattle or plastic? Ours sounds more metal like so I think it might be the power slider motor or something. Will have them look closer next time it goes in. Guess it could be a hard plastic rattle.
Tyler
Definitely a plastic sounding rattle . I plan on having the dealer look at it next time i have it in but wondered if anyone else had the same issue . Or if it was completely normal . I´m fairly certain it is the vents because it mainly does it if there is a influx of air into the cab.
Ah gotcha, mine does it on slightly rough roads with a bunch of small bumps. Never noticed it with the air. Will check though if that does anything.
Tyler
Mine started doing the same thing after I took it into the shop for some power train work - software update and new torque converter. It never made this rattling sound before, nor does a new truck make the noise. Mine has just over 5K miles on it, and almost always makes the noise when closing doors on the driver side and sometimes going over rough surfaces. Why should this be considered an acceptable situation?
Totally agree when a person is spending this kind of money the expect certain quality . My 02 did not come with a 5 piece drum set behind the seat ....
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
