BIG FORUM NEWS
Zane
I just wanted to keep everyone updated on some major happenings here at GM-TC! We will be moving to a NEW forum software soon! Work will be going on through out the week, so it may happen tonight, or not untill this weekend. I'm not sure.
The new software is mainly to fix alot of little bugs that this one has in it. Such as not giving out lost passwords all the time. Plus, it is faster, and easier to use.  :chevy:
We have been using the new software on SilveradoSS and GM-Cars.com for a few months now, and deem it acceptable to handle this forum and its large load.
So, if the forum is down for awhile, its all good!  :cheers:
closed, becuase we are now here!
