2015 2500HD Lightbar Lights
Thanks for the comments! I've been taking a lot of pictures, I know a lot of people want to see the wiring. Before I share what I've done I really couldn't have done this without the help of a previous post by colton_m and AZelkhunter and others located at this link:
http://www.gm-trucks.com/forums/topic/161931-need-multifunction-switch-instrument-panel-diagram/ You have to dig deep through the thread, but it's all well worth the read.
I used factory switches, I bought two switches to make one switch bank and changed out my current one. So I spent a little extra money but my goal was not to drill any holes or tap into any factory wiring.
Old Switch attachicon.gifold_sw.jpeg New Switch attachicon.gifFinished_Sw.jpeg Left Overs attachicon.gifLeft_overs.jpeg attachicon.gifclose_up.jpeg Installed
The available switches from the dealer are all listed in the link I posted. I bought them from here,
http://www.cheapestgmparts.com/
I think about $50 a switch. I have a lot of detailed take apart pictures of these switches if anyone needs them, I had to break two unneeded switches just to figure out how to get them out without breaking the needed ones.
Picture limit forces me to continue my wiring pics in a different post.
thats funny, i've always used gmpartsdirect.com (didnt know about your site) and its pretty much same exact site but parts are couple bucks cheaper...thanks!
That was great idea to get that panel and use for aux switches.
I checked the site for that switch cluster with all those aux switches and i cannot find it. They only have the one with 3 switches which i currently have. I even switched the vehicle to the denali and still cant find it
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
