Greetings all... new in WI
Rdgdawg
Hi All,
Just got my truck about a month back and decided to post after reviewing some of the posts here in regards to exhaust. GREAT info and thanks to all offering advice. I decided to remove the muffler and go with a Magnaflow Glasspack. Got EXACTLY the sound I was looking for, not too loud but deep bass and power, my truck's already been nicknamed "The Beast." IN fact my 12-year-old daughter insisted on making it sound meaner (I know, will post sound video soon). Look on her face when I fired it up said it all :thumbs:
Look forward to discussion and being a member!!!
Rdgdawg
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
