GM 6 piston Brembo Big Brake Kit 84050685
We should have had a mini-meetup for the Indy area guys! I was there too.
I was there Friday but had my car parked by the fence close to the finish line
Ryan
  • 3 months later...
  • Replies 52
Just a update guys, Looks like GM changed the part #
6-piston Brembo brake package - 84109402 - Q2 2017
84109402 Performance Front Brake Kit – 2014+ Silverado 1500/2015+ Tahoe and Suburban The Chevrolet Performance front brake system features red Brembo® six-piston, fixed aluminum calipers loaded with brake pads clamping on larger-than-stock 410 x 32mm (16.1-inch x 1.3-inch) Duralife™ rotors coupled with a 68% increase in brake pad area to increase system thermal capacity. Duralife™ rotors feature a hardened surface to reduce corrosion and provide quieter braking with less vibration. The brake package includes all necessary hardware and installation instructions. This front brake system is available for any light-duty 2014+ Silverado and light-duty 2015+ Tahoe/Suburban with 20-inch – 22-inch original equipment or GM Accessory wheels.
  • 1 month later...
Thanks for the info on p/n change, been trying to get info on this setup
What about the rear though? I would hate seeing different rotors and calipers front and rear
  • 1 month later...
FYI, brakes are available.
GMC = 84263235
This GMC branded Performance front brake system features red Brembo® six-piston, fixed aluminum calipers loaded with brake pads clamping on larger-than-stock 410 x 32mm (16.1-inch x 1.3-inch) Duralife™ rotors coupled with a 84% increase in brake pad area and a 42% increase in rotor area to increase system thermal capacity. Duralife™ rotors feature a hardened surface to reduce corrosion and provide quieter braking with less vibration. The brake package includes all necessary hardware and installation instructions. It is compatible with 20-inch – 22-inch original equipment or GM Accessory wheels (except SEU wheels).
Part Name:Brembo® Performance Front Brake System
GMC Sierra 1500
GMC Yukon
GMC Yukon Denali
GMC Yukon XL
http://www.gmc.com/accessories.html#also 10% this month. enter "TEN4MARCH" at check out.
Chevy = 84263234, not showing on Chevy yet but its in the parts catalog for 2017, http://mobile.epaperflip.com/?docid=e34bf0cd-4da2-4d9d-87c2-a6a900f02c2c&page=1#page=64
There's nothing for the rear though?
Nasty I agree it would look better yet cost more, however the fronts do most the work about front=70% to rear 30% or close to that, I remember installing CTSV brakes on my 2002 SS F-body they where monsters, It made a very substantial improvement.
I hope the calipers aren't all branded Chevrolet for us GMC guys.
on GMC's site it shows small pics but it says "GMC" on the caliper, Chevy is a different part number.
GMC = 84263235
Chevy = 84263234
  • 2 months later...
  • 3 weeks later...
While they sure look good I don't have that kind of money to drop on those. I really wish I did though.
Has anyone purchased and installed these yet?
  • 1 month later...
    AidenVorpagel
    AidenVorpagel
  • Who's Online   4 Members, 0 Anonymous, 1,372 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
