BCM modify?
So I've looked around here and didn't see anything that would be equivalent to this cable that I use on my car. I use this tool to plug in and connect to my ECU, then I can change options or coding through the cable on my laptop. I would like to know if there's a cable for our trucks like this and where I can get it to do the same to my truck as I do with my car. It's also used to clear codes and all that too.
http://store.ross-tech.com/shop/VCHUC.html
Your not really going to find a good CAN bus system reader they are basic fault code readers at best, the GM tech 2 and GM laptop offer the only true solution. I wish someone made a high and low voltage canbus & protocol diag.... reader, that's where the pros/engineers diagnoses level is at.
Ross-Tech is for VW's/Audi's. I have one for my VW and it works great but it will not work on GM's. I don't know of anything except a Tech 2 for GM's. EFILive & HP Tuners would do a lot but also tune which make them a lot more expensive.
Jay
Your smartass, condescending euro-prick comments
are not welcome here. Keep them to yourself or find another euro-prick forum.
Sent from my SM-T817V using Tapatalk
I see I found the village cry baby in the group...
I have been a GM guys for decades now and recently picked up an Audi for the wife (2016 Audi SQ5). With that and as said, there is no such thing for the domestics as you have found for the VW/Audi vehicles. HP Tuners and EFIlive only have access to the ECM/TCM for tuning, most of the items you are wanting to change are controlled by the BCM which we don't have access to currently nor I doubt we ever will.
I see I found the self-assuming elitist who thinks he is so much smarter and better.
Oh, and your welcome for all the information given here.
Sent from my XT1254 using Tapatalk
Again, why be a douche bag? Go back and read what I originally wrote, nothing was bad about it. Thanks for the info but the comment after that was ridiculous.
Ok, fair enough, you're right. I want to retract my statements and apologize for being a douchebag.
So, now if you will explain what you meant by:
Figured there would just be silence...
I was just being impatient not getting a response, also didn't know if there was such a tool with the silence. It's not common to hear that you can use a tool that I linked and change so much in the ECU. I mainly wanted to know if there was something similar so I could code the truck to play movies while in motion for the passengers. I also wanted to use it to roll all of the windows down and open the sun roof by holding down the unlock button on the FOB and close it by holding the lock. There's a ton of things you can do with this tool and now that you have given me my options, I don't see myself doing any of that any time soon unfortunately. :sigh:
The Mad Veteran, I have spoke to handfuls of guys that have modified the BCM all with different degrees of success, example GMC sierra SLT added a Denali cluster on the K2xx trucks, not easy to do. Most of them keep this information as a safe guard and won't tell you anything as its their business, nor will they do it to your vehicle incase there is a failure, and big requirement here the truck normally has to be there in person to make it all work.
The HMI apple car play swap, is the easiest plug and play add-on for our trucks, but recoding "BCM", for windows, sunroof, etc... its not something some wants to share for free or at all.
I do wish HP Tuners had the ability to recode the BCM, all of us would be using it for sure, but they only focus on powertrain.
You should have made a thread listed BCM modify? not can-bus, I don't think you fully understand the difference.
I have looked online, the only current aftermarket option would maybe to get a PICKIT II programmer and start leaning to code the BCM
I bought the cable and software off eBay for my wife's Highlander. It's funny that higher quality manufacturers aren't locking out these things.
I wonder if it's the same with the cluster as in my car. I swapped mine out for an updated model and all I had to do was go to the dealer for them to unlock the security/locking error it kicked out when I did the swap, after that it worked perfect. I would love to swap for the Denali cluster!!!!!
Yeah I'm not familiar with the BCM yet but I'm sure I'll figure it out and find a way to alter what I want as I did on my car. This is my first pickup so it'll be a learning process for a bit until I get it all down as you would imagine.
I will check out the PICKIT II and the other programmers suggested, thanks everyone for the noob questions.
I also changed the header to "BCM modify?"
I wonder if it's the same with the cluster as in my car. I swapped mine out for an updated model and all I had to do was go to the dealer for them to unlock the safe/locking error it kicked out when I did the swap, after that it worked perfect. I would love to swap for the Denali cluster!!!!!
the others have not listed anything that can change or modify BCM coding/functions. Even the pickit II may not be able to its just a theory I have, we need to view data, then learn to read data, then possibly modify it. tools like snap on vehicle interface but you must use "GM subscription" and only works with the VIN or VIN available options, there are lots of options esp... in different countries but GM wont let us access them, as its VIN based.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 914 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
