Bed Extender
Any recommendations for the best bed extender? I have the super cab with regular length bed. Need one since my motorcycles will not fit without the tail gate being open. Thanks.
Thanks Bob. The Lund version seems to be the most popular, for a reason I guess.
I think I read somewhere that Lund bought out AMP Research, don't know what they are going to do with two product lines that are the same.
Amp research works perfect for me 74f2fd182883a366e8353f1e2bf710c0.jpge20f65fab17d8eec965486623d526249.jpg
Sent from my LGLS991 using Tapatalk
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
