4.3l v6 chevy silverado 1500
You don't have one. 2004 was the last year the 4.3 had an inline fuel filter. The only sort of filtration for the fuel system is the strainer/filter that is part of the in tank fuel pump.
Dam that sucks so pretty much I'd have to replace the fuel pump
Also I'll tell you what it's doing maybe you could tell me what it is if you could please
So I've replaced my spark plugs and wires. Also replaced MAS sensor and it runs like crap. It pretty much doesn't want to run and when it does I can't even go 45 without it almost wanting to cut off. The only thing I have not done was replace my distributer cap and distributor. And I don't have a pipe it was cut off after the catalac converter.
Are there any codes present?
The last codes that were thrown was the coverter mas and random misfire but I haven't gotten them checked again cause I can barely drive it without it wanting to shut off.
yes the fuel pressure is where it needs to be but I have not checked my injectors either.
