There is always the 88-98 C/K series.. those were dang good trucks. All you had to worry about for major failures was the tranny every 150,000 miles.
  • 2 years later...
On 5/27/2016 at 8:55 AM, fondupot said:
First off I'll explain my normal starting procedure. I put the key in, turn the key forward to run, but I don't crank over the key for a few seconds, then I crank the key and the truck starts no problem.
So today, I get in to go to work, put the key in, turn to run....and here is where the issue begins. I had about 1/2 second of power (the radio came on and the dash lights flashed). Then I heard an electrical "thunk" sound (best I can describe it) And then, the truck was dead. Like dead, dead. Like Doomguy impaled by Hell Knight on ultra-nightmare dead.
I tried to crank it over. Nothing. Not a sound. No clicking, no nothing. Dead.
Key fob doesn't do anything. Windows do not work. Lights to not work. Locks, overhead lights, etc etc. The truck is a 5000 lb. paper weight.
So a this point I am scratching my head. I pop the hood and check the starter fuse and starter relay. Fuse looks OK. Relay didn't show any signs of trauma, but it's impossible to know if it's bad just by looking.
So now I am stumped. And getting pissed, because I am going to be late for work. I came to my senses and thought maybe I should disconnect the Negative battery cable. So I get my socket out. Unhook it for about 30 seconds. And then reconnect. Tested the key fob. No affect. Still dead.
Then I decided then to disconnect the positive cable. So I did that, for about 30 seconds. And then reconnect. I tested with the key fob, and to my surprise I had power. The lights flicked on. So then I hop in and try to start the truck and it cranks up like normal. Drove away to work. I had to stop and get gas, and I was nervous to shut the truck off. But after filling up, it started like normal with no issues. Had to make another stop on my way to work, and it started fine again.
Really strange.
Any thoughts?
Thanks dudes/dudettes
SO this happend to me with my 2014 Sierra I bought used 4 months ago. I had to have it towed to a shop and of course for them it started right up however I had the battery negative off because while trying to start and jump my truck I found the negative was extremely hot.  The shop hooked up battery and could not duplicate the issue, however they found a service bulletin about the BCM software being out of date causing no start no crank no power issues. I had them update the software today and will see how things go as of now picked her up and everything is fine  here is the link for the bulletin
https://gm.oemdtc.com/7614/13257-service-update-for-inventory-and-customer-vehicles-bcm-communication-error-reprogram-bcm-2014-chevrolet-silverado-gmc-sierra
I hope this info may help with the many posts I’ve seen describing this issue!
Perhaps this is what the link refers to, I run an ad blocker and that site refused to load. Don't these trucks have a 'battery saver' of sorts that 'disconnects' when voltage gets low to save enough for a start?  If that thing went haywire and got over-aggressive couldn't it cause issues like this?
Several similar issues posted here - Mine died about 3 weeks ago: new battery did not solve issue, new negative battery cable and things are good 10 days into it. lots of 2014's experiencing this: new cables fixed many a recent one was the park/neutral switch.....keep posting issues and soiutions
Well that wasn’t it!  Today same shit, no crank no start did finally get dash to come to life and stated low bat.   Theater bat and all is good so disconnected negative for 10min hooked back up and it started right up no problem. Ugh $420 a week ago for nothing!
Next project for me will be tear apart the dash and check the 218 ground as I’ve seen a few people find issues and fix this ground and had no issues yet. I’ll update after I get time to try this fix.
My Dad had an 88 K2500 reg. Cab Long bed 4x4 454.
Tranny blew at 60k
Other than that, it had 0ver 350k when he sold it 5 years ago.
It was a farm truck used and abused.
Some minor rust at cab corners and peeling hood paint.....
Was the best GM vehicle our family ever owned.
I had a 94 short bed Z71 and sold it in 2000 with 82k.
Not 1 single issue.
So I second yournod to the c/ks from 88-98 being the best! :cheers:
Edited by Sierra Dan
  • 7 months later...
any up dates, I'm having the same issue with my 14 Rado?
  • 9 months later...
I have two 2017 Chevrolet Silverado's. On Saturday my Son was driving one of them. When he stopped the vehicle and then tried to start it nothing happened!!! The lights, radio, windows, locks and everything else works but it will not start. No clicking, no turn over at all. We have around 47k miles on it and it was running fine since new. Any ideals? Let me know.
Nick
Nick
   I have a 2018 Silverado with 42k.I had to replace the starter.LOTS of problems with starters in trucks of these years.
I recently had a similar issue with my 14 sierra slt (5.3) ... truck had zero power. Completely unresponsive... i eventually got it to start and somewhat brushed it off. It happened about a week later...
Since i recently bought the truck, it was still under warranty by the (gmc) dealer... they decided they would send a tech to come look at the truck at the house.. before they towed it.
The tech couldnt figure it out, but after doing some research the night before i shimmied the negative ground cable on the battery. It had power instantly.
They replaced the negative ground, and so far so good... a bit concerning though. (hope its not a sign of things to come)
I been having the same issue (without the clunk noise).  I’m in a 2014 Chevy Silverado 5.3L as it was dead dead and I tried disconnecting the battery with both post at the same time.  At that moment I realized the negative cable was slightly warm. The volt meter was reading 12.4 volts.  Then after about 2 minutes it connected them back.  My truck screen went on and then started up like normal.   I then let it run for 10 minutes.  Turned it off and on 3 times.  I left for 5 hours and came back and it was dead dead again.  So I repeated the process again and it started.  May be a loose ground? Or some new security feature which protects the computer? If this continues I will check my ground.  If it still continues I will bring it to the dealer.
Edited by Scotty Landreneau
  • 10 months later...
32.5k miles 2019 LD basically the 2018 model intermittently wouldn't start always cranked over threw a bunch of basic engine codes engine start fail shop almost gave up finally it did it while onsite was the starter. Just cause it cranks over don't rule out the starter!
  • 5 months later...
On 6/13/2016 at 11:26 AM, 20feetup said:
Have you had the issue reoccur at all? Did you have it looked at? My issue has returned even after the cable change...
Ours was the EGR valve sticking open. Wait a few min 10 to 20 then restart. It was mess but found a fix.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
