bigger tires bilstein shocks
i have a 2014 silverado rally edition. has the stock 22 inch wheels running 285/45/22 bridgestones . all stock i was going to put a set of the bilstein adjustable shocks on front to raise front up to level with the back. i can buy a set of nitto g2s really cheap brand new they are 285/55/22s will these tires fit without any issues .
285/55/22 are 34.34 inch tires. I am 99.9% sure you're going to have issues on just a level.
what would i need to do to get these to fit
Wish I could tell you, but I don't know for sure. Guessing some sort of body lift, 3" maybe?
Sent from my SM-G930V using Tapatalk
They'll fit, but they're quite a bit taller, so they'll definitely rub... 3" level might work. If it's 2WD you can get the 3" lift spindles, it'll lift your front end while keeping your suspension angles perfectly level. Maxtrac Lift Spindles #701330BL run about $450. Worth it IMO
it is a 4wd . i did get the tires yesterday they are brand new never mounted 285/55/22 terra graps g2 paid 850 for them couldnt pass that up. now have to figure out what i need to do to get them to fit . talked to the tire shop yesterday he said maybe with a level kit not sure. hes been doing this for yrs very knowlegable so hopefully not to expensive of a lift level or whatever is needed should look good when im done i will post pics thx
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
