So got under the truck last night with a plastic mallet.
Nothing seems to be loose.
Today went for a drive to try and define the parameters that set it off.
I noticed that I can make the noise happen in v8 mode too, but the frequency has doubled over the v4 noise.
I was able to get the truck to maintain velocity and rpms and switch from v4 to v8 and noticed the difference.
Edited by Jonty711
Yeah, it just sounds louder in V4 because the frequency is less drawing you to the noise more. Mine doesn't even need to warm up to make the noise. I did it less than 1/4 mile from our lake house this weekend running across the landing.
I have found that mine is usually quietest in the morning (cold or at operating temp). The road I drive that takes me to my highway commute is smooth and 55 mph. Truck is quiet as a mouse until you hit the first jarring bump on the on ramp. Then it varies in noise level all the way into work on the highway. Seems like after the engine sits all night and "settles" in the mounts (or the offending part settles) it is quiet until disturbed.
It almost has to be fuel system related because of the direct link to throttle position and that the frequency changes while in MDS (4 injectors aren't being used during V4).
I was yanking around on the fuel return and supply lines under the truck yesterday, they have a fair amount of motion to them. I am going to try and zip tie those into a different position to see if it changes anything. I am also going to ratchet strap the engine with some downward pressure on both sides to see if that goes in line with the bumps/hitting the brakes hard symptom.
Mine is not directly related to throttle position. It is linked to RPM. If I'm at a high RPM and let off the throttle to slow down the ticking noise continues even off the throttle and slows down as the RPMs lower.
Mine will do that at RPM as well pending how loudly it is currently acting. Its extremely throttle position related at lower rpm.
That's how I found out you could mash the brakes and make it go away. I dropped the gears manually the other day when it was super loud.
I also tried to turn the truck off while in a high gear to see if the noise went away but the programming on this truck immediately unlocks the TQ and the engine stops. Other trucks I have had would keep the TQ locked if you just turned the key to accessory then they didn't need to be started again, just turn the key back to run position.
Hi, so my 2014 5.3 L83 truck at 38k miles still ticks just like a lot of guys here, but I have upgraded the air intake, Bigger 6.2 manifold, ported stock heads, DOD delete kit, new 660 lifters springs and  trunnion kit, custom cam, headers with side exhaust and it’s still ticks but it’s more pronounced under load(AC on). bumps and hard turns can make it stop but soon comes back. Next for me would be new oil pump or  vacuum pump.
Would these throw codes if you went for a short drive with the vacuum pump disconnected ?
Things that are isolated to divers side only are fuel lines/vac pump.
Kinda dangerous driving with the vac pump disconnected.
1 minute ago, 20165.3Eco said:
Plenty of private property to cruise around on.
I would think it would throw a code. Let us know if you find anything.
Will do. My co worker has had very good service from another dealer in town. Last effort I’m going to have that dealer take a look at the truck in 2 weeks before my warranty is up I still own it then. After they can or can’t fix it then I’ll dive back into working on it.
Thw truck is so pleasant to drive when it’s quiet it’s a shame it makes these noises.
I get ya. It’s 98% perfect, it’s just a couple of little things that take the joy out of driving it. I have 1 year left on warranty.
It will do it in 4 or 8 mode. Light acceleration or holding speed is most noticeable. Mine can be beautifully quiet for long periods of time until you hit a bump that moves the engine around then it will start making the noise. Stopping long distances and taking off lightly from a stop sign or light usually makes the sound go away again until you hit a bump.
Interesting development. So this evening, I go for a small blast, and park up and leave the truck running. After 2 to 3 minutes of idling, the truck starts making the a noise similar to the under load tick, and sounds like water sloshing around.
Sorry it it was hard to describe and only lasted 10 seconds.
Has any light come to this situation yet love how the Denalis are sold as having a quite cab. I can say in park running it is very quite
    250.6k
    President Roberto
    President Roberto
  • Who's Online   3 Members, 0 Anonymous, 1,068 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
