I've been looking for this subject for a while, I'm going to my parts guy to get this done on mine., cooldaddygrove could you specify what exactly is working and what's not. I know you mentioned a few things but does the A/C works?
Thanks!
Thanks!
Everything works just like the standard head unit. Yes the A/C works What doesn't work is"
  • Auto climate control (obviously because I don't have a sensor installed yet)
  • Dual climate control (wasn't expecting this functionality anyways)
Thank you for your response. Ill definitely be doing this upgrade, don't really care for the dual climate feature. It just looks a lot better than the standar one. Let us know if the sensor works, I might get that one too.
Thanks.??
Still trying to figure out how to post pictures from my phone going back and forth from the mobile to full version, so I purchased the sensor I only need to buy the unit with dual zone, does the part I added looks right to you? Questions and comments are welcome.
Yup, thats the same part # I bought online. My dealer is going to install and test it for me next Monday, so we will see how it works
I bought the unit today, I should be getting it by the 19th, so we'll see once I get it., hopefully the automated temperature works, if not this ac unit looks 10x better that the standard one.?
Well, in the end the sensor didn't help. So if anyone is interested in a brand new HVAC control unit to dress up your truck, drop me a PM
That's not good... Did they say why?
They said I needed more parts than just the head unit and sensor. Oh well, that was fun.
I installed the new unit yesterday, and I really like this way better than the standar one, I knew the was going to be a very high chance that dual or auto function weren't going to work, but I'm really glad I did this. I'll continue on my quest to figure out the auto and maybe someone might figure it out.
Man, some guys just don't like hearing the advise that people who work on this stuff and program this stuff give. You wont be able to get the auto to work, the HVAC from a non-auto truck to an auto truck is completely different. The airbox system, controller, sensors and programming is not even the same. Unless you are going to pull your entire dash out to the change the airbox and then also replace all of the sensors and then see if you can find someone who can custom program the HVAC module (Dealer cant and wont be able to) then all you are doing is throwing money into the wind.
But hey, not my money so go for it.
Alright, so it’s been a long time since a wrote in this topic, but later I found out that the auto does work., my truck didn’t come with the dual zone control and after installing the one with the dual, realize what a lot of people have done after me., installing regardless if it doesn’t work. But as I said the auto does work on my truck when turn the fan off and press the auto it comes on and turn gradually as it gets to the temperature set., now I’m on the quest of continue with this upgrade. After doing a full 16 front conversion, adding the ac/heat oem leather seats to my cloth heated seats, fully unlock my HMI adding the flip down screen and having it fully functioning as factory thanks to @pgamboa and @GTPprix. I believe that the only module requires to program is the HVac module., after obviously added the required harness, sensors and etc. I have successfully swap my non leather dashboard to a HC leather dashboard and taking apart the whole dashboard I feel confident that this might doable. The real failure will be not to try. So I’m going to take my time on this one and after @GTPprix is not as busy as he’s now I might send him my module to program it. If thats an option.lol.
Forgot to mention that I have an 18 dashboard with all the ducts needed and the harnesses that I might use for my truck., so the most important one will be the module. I wonder what the RPO for the dual zone climate control is or if it’s actually one. Will come back with the result once I find out more about it.
    250.6k
    Aries68
    Aries68
  • Who's Online   0 Members, 0 Anonymous, 359 Guests (See full list)
