Interesting led headlight situation
Do even the base or work truck trim level trucks get these new LED lights or only the LT or LTZ trim levels?
I believe they come on the ltz, slt, high country, and Denali only. Work trucks up to lt get a d5s xenon hid projector running back 25w ballast.
How do the Work Truck trim level headlights then compare to the '14 and '15 Silverado's? I am happy with the stockers in my '15. I never did like the look of a conventional halogen bulb in a projector housing. That's just me though. I was nervous about light output on the 16's so I bought a '15 Silverado instead for that very reason.
The LEDs are whiter - closer to noon sunlight - as measured in degrees Kelvin. I would guess somewhere like 4000*K but possibly inching toward 5000*K.
The rods and cones in the human eye actually see better in that wavelength, opposed to nearer the yellower end of the spectrum. (2500-3000*K). The CRI, color rendering index, is very high for most LED meaning what you see is also more accurately depicted color-wise.
You may note your own local communities/cities adopting the use of LED street lighting, in no small part due to these increased visibility issues. They are highly aimable and certainly use less energy to generate equivalent lumens (such as from HID or even high pressure sodium).
High Pressure Sodium (HPS) is considered High Intensity Discharge (HID) along with Metal Halide, and even the old Mercury Vapor.
Yes Colossus, I was distinguishing only as the metal halide/merc vapor art significantly whiter HID, opposed to high- or low-pressure sodium that is clearly yellow or orange.
Your truck runs an h11 low beam which I believe is 1300 lumen a piece. The new trucks that have hid (which is everything under the ltz trim level) run 25w ballasts, and d5s bulbs that produce 2000 lumen each. So 2600 lumen with your setup compared to 4000 with the new hid. A fxr retrofit in your headlights using 35w-55w ballasts would produce 6400 lumen combined with d2s bulbs, or close to 7000 lumen if you get cbi bulbs. I don't know the lumen output of the new led headlights yet but I'm researching it.
I'm interested in that. Lumen output and color temp. Thanks
The info has been a little hard to come by so far. I would say the color temp is 5000k-5500k though.
It sure gets confusing reading about Silverado and sierras in the same thread since they're both totally different
Lights.
Lights.
The projectors are the same in both Hid, and led.
On the Sierra's, the inteelibeam LEDs are an option.
    250.3k
    chfkief
    chfkief
  • Who's Online   1 Member, 0 Anonymous, 1,573 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
