7 hours ago, texasaggies16 said:
Looks much better! did the 14-15 to 16-18 swap on my Sierra, all LEDS FTW!
Nice, and thank you! Yeah, I was looking at a 15 Sierra and said if I were to buy it, I would do the same thing. You made a wise choice my friend lol.
Edited by DBrach
  • 3 months later...
12 hours ago, oswaldo unger said:
what all did you have to change on the front end to get the 2016 look, i aswell own a 2015 and love the 2016 models.
The list is in this thread. If you have trouble after reading this thread, shoot me a PM.
  • 4 months later...
Super interested in doing the opposite for this, I have a 2017 and prefer the 2014-2015 front end.  Anyone in the pacific northwest and want to trade?
I was able to almost break even for my swap out. I was able to sell all of my old parts for about the same cost is what I bought the new ones for. It took me almost a year to find and buy the new parts for the upgrade at the cost I was willing to pay. When I say new, I mean the 2016 version. Out-of-pocket I think I was $800 and that was for painting my front and rear bumper to match.
In regards to doing the reverse conversion, I believe it would work just the same way but my initial thought and only concern would be how to retrofit a plug-and-play wiring harness to go from the 2016 LED headlights to the downgraded halogen headlights. But that is probably a gen5diy question or a PGamboa.
Great info, thanks! is it only the grille and complete headlight assemblies?  Or do you also need brackets and radiator support, etc...?
Edited by Zakk
Zakk and I have spoken and will likely be swapping front ends.  I will be swapping from a 2015 Silverado LT and I think his is a 2017 with LT headlights, not LTZ and no fogs.  I will be looking for the 16+ bumper with fogs to complete the conversion.
I do have a question for those who have done this conversion. The wiring kit that is available from Gen5DIY I have seen available for this 15 to 16+ LT conversion has a description that states that the parking light function does not function correctly.  Specifically, the headlights stay on, rather than go off.  I would like to make sure all the functions work correctly.  Is there a harness that allows all the factory functions to work correctly?
[mention=159655]pgamboa[/mention] from harnessdr.com is actually working in this particular issue, I have the gen5 harness which works properly but it doesn’t function as factory set up.
I will be getting Phil’s harness as soon as completed and install on my 16 conversion.
Nice!  Hopefully it comes out soon.
I have a 2014 Chevy silverado and converted the front end to the 2016 front end.  My trouble is, how do i connect the headlight to the harness because the light are totally different.  do anyone have a diagram that can help me connect the headlight up correctly to the old existing harness.
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 267 Guests (See full list)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
