2016 Silverado Dash Trim
I was wondering if the Silverado LT z71 model come with the white stitching around the radio and vents on the dash? I test driven a 6.2L LTZ and Silverado Custom model, I know the LTZ models has a soft touch feel with white stitching. The custom model has plain black plastic....
Im just curious on what a LT z71 model would come with? would it come with a plane plastic frount dash like the custom model or??
I like to know because i'm buying a LT model in a few weeks when the dealer gets a specific truck in I wants.
Go check out a GMC. My sle has that stuff. And I got it for the same price as the Silverado LT.
Nope only ltz.
^What he said. Only comes on the LTZ package.
I believe he is talking Chevy Silverado trim packages. The dash is part of the trim package. LT doesn't get the upgraded dash, you have to go to LTZ to get the soft dash with stitching.
Just built a 2016 with same interior as mine in Chevy LT. This interior is also available in LTZ.
Jet Black, Leather-appointed Seat Trim Includes 10-way power driver seat. Includes (KA1) driver and front passenger heated seat cushions and seat backs.)
In order to select this feature, please also select one of the following :
  • WT/LT Convenience Package$1,510
  • Texas Edition$2,280
  • All Star Edition$2,280
You are right, If you order it specifically with a add-on. Most LT's on the lot aren't going to have this trim level.
Just like most LT trim leveled vehicles aren't going to have leather either unless specifically ordered that way.
To answer the OP question, I guess the answer is yes, if you specifically order it that way. But an LT doesn't just come with it. A LTZ does just come with it. :-)
Swear to whatever deity you believe in I have seen it in LT with my own eyes. Exact same interior as mine literally could not tell the difference(except the chevy logo on steering wheel) However that was 2015 and not 16.
The interior option on the Lt is seats only as listed in your own description. I have been in over 50 14+ Lt trucks and not one has the stitched dash. Not saying it is not possible but i have never seen one. Try looking at dealership photos of Lt trucks with leather country wide. I would love to be proved wrong on this, i like the stitched dash better too.
Every sle truck i have seen has the stitched dash.
Ah there is the rub, this interior is not leather. Nor is mine it is cloth seats with leather appointed trim, I could be bonkers but as stated I could swear did in 2015 but that was a year ago (or more) by now so maybe it was just black stitching and my brain is thinking 'meh close enough'.
LT Z71 comes with soft touch dash, no stitching, silver plastic trim next to dash vent panels. White stitching on the (leather) seats, console and doors; black carbon fiber Z71 branded cluster, chrome Z71 logo door sill plates, HD rubber mats and silver carbon fiber door handle insets.
Please go buy a ford. They don't have it. Life goes on some how. Sorry if that is your first post about push button start but i am so damn tired of reading about how gm does not have it and others do.
