Need Help Building My Truck
I don't know much about shocks and suspension and was wondering if someone could help me out. I have a 2wd 2014 Silverado, and want to get a 3.5 or 4 inch lift. I was thinking Rough Country but heard their UCA's aren't that good. I was thinking of getting Cognito UCA and also wanted fox shocks. I see they are very popular and give a good ride, and was wondering which ones should I get? I want to hopefully be able to run 33 inch tires and 22x12 wheels. If someone could please tell me what setup is best, it would be greatly appreciated. Thanks
There is a member on here that has cognito uca's with coil overs and he had issues with his front suspension over extending causing his uca's to hit the mount for the bushings (if i remember correctly) and it was gouging his control arm. Not sure if he found a fix as he contacted cognito or fox or both to have the issue resolved. Just an FYI
Since it's 2wd, u can look into a 2" level, and 2" lift spindles. Total of 4" lift and much cheaper than going with all new UCAS.
Just another idea
I don't mind going with a 4 to 5 inch lift, as long as recommendations are made for which shocks I need to buy and if the lift is long lasting. I don't ever take it off-roading but I do take it to Mexico once a year and I do have to drive through some mean rocky roads.
Have you check out your local tire shop , off-road shop - for any information ??? just ideal
