Bargain week
Damn that's hard on the wallet!
Screenshot_20161110-221743_zpsmbpwpnjl.j
No more kinked lines going through the firewall though. Yay another audible stepper motor gauge.
  • Replies 324
So I have to ask, how much has the "Bargain Week/bargain months" cost so far? :eek:
Not counting my screw ups, and the labor for the oil pan and o2 sensor bung, 3200. Less than a vortech kit for a gas engine. They don't make a kit for a flex engine of my vintage, or I would have gotten one. The labor for the oil pan and the o2 sensor bung was about 240, but I know the owner of the shop that did it for over 15 years, and he charged me for actual time, not book time.
Muddkatt, I was so pissed about the kinks in the boost gauge tube... I almost took the gauge and threw it. Then Mr Miyagi piped in with "In through the nose.... Out through the mouth..."
I know the feeling tooooooo well. In my younger days, Mr Miyagi would not say a word, then run and hide while the well deserved fit got thrown. Now he comes around, sometimes he talks, other times he decides he wants to see if I have learned to control myself. :devil: Depending on the price to repair whatever it is makes a big difference in whether it should be "sledge-o-matic" or I should take time and regroup.
If you are not old enough to remember the sledge-o-matic, here is a clip you will enjoy:
The audible stepper motor in my afr gauge is getting on my nerves a little. I'm stubborn and I refuse to give up believing in Autometer quality. Perhaps packing sponge in the pod around it will muffle it some.
Got some much needed work done today. Found another bargain at the junkyard too. First and foremost, I replaced my fuel pump module. I imagine that the filthy black strainer on the old pump was at least partially responsible for barely making 40psi in the rail. Makes 50psi no problem now. I'll have pics of the old pump after Monday, as it is airing out. While my Burby was in the air, she lost a little weight, too.
Now I can get to the sanding and application of bedliner, undercoating, etc. Had to cut the running board brackets off, as 1/3 of the bolts attaching the brackets to the frame are torx head, rusty, and easily stripped.
Passenger's side, front to back.
Driver's side, back to front.
Driver's side, front to back.
Passenger's side, back to front.
And my $13.40 bargain
Got my new boost gauge today. Yaaaay! This thing is sexy, as it should be given the price.
Also, while I was having the fuel pump replaced, I found the rear brake backing plates to be in very poor shape. No biggie, I already have the dorman plates at home, and 3 quarts of mobil 1 gear oil. What I didnt have is new parking brakes, because even by my vin, there are multiple options and the only way to know is to take it apart first. I found this box of awesomeness instead.
And it's contents.
Since I was asked about the ever increasing dollar value of my bargains, and I get to work from dark till dark on a Saturday, I'll go ahead and give everyone a rundown so far, not including my screw ups or shipping. I pay 7% sales tax locally, and that is included. I will be adding to this list as little incidental things arise. Also, I already had HP Tuners VCM Suite before I started this project, and I keep a well-stocked toolbox for automotive electrical work. I also happen to work at a car dealership, so some of my prices may vary significantly from yours.
1. Vortech 2E128-040, S/C, V2 SQ Si Trim, Curved Discharge, CW Rotation, Satin Finish. Purchased new on eBay for $1050.00.
2. 3/8x16x2.25" Grade 8 Hex Flange Bolts (5), Black Oxide Treated. Purchased at ACE Hardware for $12.25.
3. Vortech 4GL011-021, Mounting Bracket, LS Truck. Purchased from Summit Racing for $236.99.
4. Vortech 2A036-333, 6-Rib, 3.33" Supercharger Pulley. Purchased from Summit Racing for $81.99.
5. Vortech 8R101-001, Retainer Assembly, 6-Rib Pulley. Purchased from Summit Racing for $10.99.
6. Duralast 231081, Idler Pulley, Stock replacement. Purchased at AutoZone for $21.39.
7. Oil Pan, 2002 Tahoe 4x4. Purchased used at U-Pull-It for $25.67.
8. Vibrant 10251A, 1/8" NPT Male x-4AN Male 90 Degree Fitting. Purchased from Summit Racing for $5.99.
9. Vibrant 10277, -4ANx48" Braided Stainless Oil Feed Line, PTFE Lined, Female Threads. Purchased from Summit Racing for $27.30.
10. Chevrolet Performance 12584922, Oil Pump Pickup Tube Seal, Late LS. Purchased from Summit Racing for $6.97.
11. Chevrolet Performance 12612350, Oil Pan Gasket, LS. Purchased from Summit Racing for $28.97.
12. Summit Racing 220072, 3/8" NPT Aluminum Weld Bung. Purchased from Summit Racing for $4.97.
13. AC Delco 213-1631 (12615136), 2 BAR MAP Sensor. Purchased from Summit Racing for $48.93.
14. Vibrant 10293, 1/8" NPT Male x -4AN Male, Straight Fitting. Purchased from Summit Racing for $2.99.
15. Aeroquip FBM1206, -8AN Hose Barb x 3/8" NPT Male Straight Fitting. Purchased from Summit Racing for $6.97.
16. Mr. Gasket R48, -8AN x 48" Push-On Oil Hose. Purchased from Summit Racing for $8.50.
17. Vortech 4GL112-010, Air Intake Assembly, GM Truck, Standard. Purchased from Summit Racing for $211.99.
18. Dayco C71799, Molded Radiator Hose, 1.31" ID. Purchased at AutoZone for $14.97.
19. Dayco E72377, Molded Radiator Hose, 1.31" ID. Purchased at AutoZone for $21.39. Regular price is $38.51. They cut me some ( a lot of) slack on it because they didn't have a stock upper hose for my truck in stock.
20. Autometer 15104, 2-Gauge Pillar Pod, 99-06 Chevy/GMC Truck. Purchased from Summit Racing for $33.95.
21. Summit Racing 220061, -8AN Weld Bung, Male Flare. Purchased from Summit Racing for $4.97.
22. Summit Racing 220840B, -8AN Flare Cap, Black. Purchased from Summit Racing for $3.50.
23. Duralast 231084, Idler Pulley, 3" OD Flanged. Purchased at AutoZone for $21.39.
24. 000955, Silicone Reducer, 90 Degree Bend, 3.0" x 2.75", Black. Purchased from Silicone Intakes for $19.99.
25. 000957, Silicone Reducer, 90 Degree Bend, 4.0" x 3.0", Black. Purchased from Silicone Intakes for $19.99.
26. T076.25-BLACK, Black Silicone T-Hose, 3.0" ID w/ 1.0" ID Branch. Purchased from Pegasus Auto Racing Supplies for $32.49.
27. 12598646, LSA/LS9 Fuel Injectors (8). Purchased used from eBay for $200.00.
28. Fuel injector Height Adapters, 1/2", 14mm O-Ring (8). Purchased from Fuel Injector Connection for $71.60.
29. Edelman 216200, 1/8" NPT Street Elbow, Brass. Purchased at CARQUEST for $1.49.
30. 000750, 2' Mandrel Bent Aluminum 90 Degree Bend, 3.0". Purchased from Silicone Intakes for $18.99.
31. 000310, T-Bolt Clamp for 4.0" Silicone Parts. Purchased from Silicone Intakes for $2.60.
32. 000104, T-Bolt Clamp for 3.0" Silicone Parts (4). Purchased from Silicone Intakes for $10.40.
33. 000103, T-bolt Clamp for 2.75" Silicone Parts. Purchased from Silicone Intakes for $2.60.
34. Fel-Pro ES70599, Injector O-Ring Set (2). Purchased at Factory Motor Parts for $6.36.
35. Fel-Pro 72435, Oil Cooler Gasket. Purchased at AutoZone for $4.27.
36. Local Welding Shop, Weld Bung To Oil Pan. Cost $20.00.
37. AC Delco 11562588, Oil Drain Plug. Purchased where I work for $3.04.
38. Genuine GM 12603782, Oil Level Sensor. Purchased where I work for $15.84.
39. Local Auto Repair Shop, Replace Oil Pan. Cost $170.00.
40. Truck Intake Manifold, Flex Fuel with Rails and Injectors. Purchased used on eBay for $149.00.
41. Duralast SU107, Air Charge Temperature Sensor. Purchased at AutoZone for $17.11.
42. Fel-Pro 72435, Oil Cooler Gasket. Purchased at AutoZone for $4.27.
43. Duralast 1143K6, Serpentine Belt, 114". Purchased at AutoZone for $21.39.
44. Local Auto Repair Shop, Install Oxygen Sensor Bung. Cost $80.00.
45. Spectre Performance, 90 Degree Elbow, 3.0" OD, Aluminum. Purchased from Summit Racing for $49.97.
46. Vibrant 2635, 1.375" OD x 60" 409 Stainless Steel Tubing. Purchased from Summit Racing for $46.00.
47. Vibrant 2787, T-Bolt Hose Clamp, 1.25"-1.5" Grip Range (2). Purchased from Summit Racing for $14.44.
48. Aeroquip FBL1523, -8AN Hose Barb to -8AN Female Thread 45 Degree Hose End. Purchased from Summit Racing for $14.97.
49. Autometer 5770, Phantom Analog Wideband AFR Gauge. Purchased from Summit Racing for $199.99.
50. Autometer 5776, Phantom Analog Boost/Vacuum Gauge, Electronic. Purchased from Summit Racing for $223.95.
51. Genuine GM 22739021, Air Box Bracket, Diesel. Purchased where I work for $12.25.
52. AEM 28-20129, Dryflow Synthetic Air Filter. Purchased from Summit Racing for $39.95.
53. Dorman 258-514, Replacement Airbox Assembly. Purchased from Summit Racing for $65.25.
Grand total so far is $3431.23.
Unfortunately, the Vortech air inlet will not connect to my AirAid intake stuff. Alignment is off by about 3 1/2". Oh well, the AirAid Kit sucks enough of my hood insulator off without the draw of a supercharger. I may take advantage of the factory hole in my diesel air box bracket and perhaps run a tube of some sort down in front of the wheel well, behind the headlight, kinda like where the AirAid one is now. I had to dispose of my stock air box because the lid was cracked, and the threaded inserts for the lid retaining screws pulled out. I may try a couple of things to enhance airflow through the dorman box.
    mighty K20
    mighty K20
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
