Bargain week
  • Replies 324
Got my pan back. Looks pretty good, I'll be dressing the weld with my dremel and a stainless steel wire wheel brush.
And with the cap I got because I probably won't be ready to hook up the drain line when I have the pan installed.
Had to clean the fitting for the filter with wadding polish and wipe it down with gun oil. It was too clean when I rinsed it, and it started to flash rust
Modded pan ready to go on. New AC Delco pan gasket, Genuine GM oil level sensor and GM drain plug installed. Not to mention clean and purty.
Old pan off. Doesn't look too bad inside. Check out the original pan gasket from 2004. Quite a bit different than the latest part number. It was leaking a bit anyway. Was nice not to find any metal at all in the old pan.
Right side leaking.
Left side leaking.
Rear main area was clean and dry. Yay. Would have taken pics underneath, but it only took an hour to swap pans and replace the pickup tube seal. Figured I'd better since it was right there.
Some of you will notice that the front of my original pan has a much larger external relief cast into the left side of it than the modded pan. The modded pan is from a 2002. There were exactly zero clearance issues with the front axle.
Stock pan is just about clean enough to put away. Little work with a brass brush around the mounting flange and another rinse to to get the parts washer solvent stank out/off of it and it should be good to put away. Why do I need it so clean just to put it away? Because I live in an apartment and, unlike the last place I lived, i dont have a storage area in the basement. I'll get pics of the stock pan a little later.
Oh, and no difference in oil pressure with the new pan gasket and pickup tube seal. About 40psi at hot idle in 80+ ambient temps.
I have not dynoed it. Sorry. Been having some odd temperature fluctuations over the weekend. Hopefully just a thermostat....
I was shocked at the amount of seepage on my old pan gasket.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
