Stainless Works Exhaust for Cheap
Guys, if you've seen my posts over the last couple of weeks you know I was looking at my exhaust options. I was about to buy the AFE Rebel system until I found the Stainless Works CT14CBY kit for about $217 less than retail. I have to imagine this is a typo on Summit's part because this system is typical $945 everywhere else including AutoAnything. All of the kits exit locations are $833.
After quadruple checking part numbers I pulled the trigger on it this morning but wanted to share the link in case anyone else was on the fence and was going to order exhaust.
https://www.summitracing.com/parts/stw-ct14cby
I'm 5.3, so the ct14cby was the kit for my factory connect, s-tubes, behind passenger wheel exit.
But good point for the 6.2 guys!
Any sound video's of this setup?
Thanks!
I tried finding one but after talking with SW the video they posted use the turbo mufflers not their louder s-tubes. They said its a similar tone just louder.
I'll do a video when I get them...in 4 weeks...
Slow boat from China?
Yup so there's two system you can buy one has the "performance connect" which only mates with Stainless works' headers and the other is "factory connect" which mates right up to the joint just before the flex joint and cats. The part number above is the factory connect.
In the end of the day it'll be stock headers into 2 stock cats, down to one pipe into 3rd cat, then the stainless works system starts, y pipe into two seperate mufflers then duals out the passenger side. They also have the Lightning style and the dual rears.
This is one the system should look like, the connection is the female side of that ball pipe joint thing just before the flex pipe
  • 1 month later...
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
