Door Chime Help
You can easily remove the door chime in the dash under the screen there is a chime box.. Unplug it and you will have no chime
Can you give more details on this? Pics perhaps. When you say "under" do you mean under or behind?
You do know that you don't have to have the key in the switch or the truck to be on at all to play the radio. Just push the power button on the radio it will play till you turn it off. Doors opened or closed. I do t all the time when cleaning my truck. Even works with Bluetooth to play songs from your phone.
As far as just unplugging the chime. It's played through the radio speakers now so if you unplug that you get no radio out of that speaker.
Awesome! I was bringing a speaker to the car wash with me for music while I detailed. Great to know.
  • 3 weeks later...
Your welcome. No need to say that though as I'm sure there are some tricks still that I'm not aware of. I bet you are not the only one that didn't know what I posted either.
I've had my truck for three years and didn't know this. Thanks.
Seriously?
LOL
Any update on location?
Sent from my XT1585 using Tapatalk
He was probably just trolling as he only has that 1 post from his account showing on the counter so far.
