NAV Volume
sk
I have a 2015 LT with NAV. When I try to adjust the voice volume the lowest setting it will go to is 21. Sometimes this is too loud and I would like to get it lower without turning if off completely. I have tried adjusting it through the screen settings and also by turning the volume knob while she is speaking the directions but I can never get it to go any lower than 21. I talked to the GM Infotainment Team and they couldn't help. Is anybody else having this issue?
Hello sk,
We’re sorry to hear you’re experiencing these voice navigation volume concerns. Have you addressed this with your preferred GM dealer? If not, we would be happy to reach out on your behalf. In order to do so, please send us private message with your VIN, current mileage, full contact details and dealership at your earliest convenience.
Kindly,
Anthony J.
GM Customer Care
Anthony,
Yes - I have been through 2 different dealers with it. I even dealt directly with the Techs on the GM Infotainment team and they were not able to help.
I think you adjust the NAV volume while the voice is actually talking.
Read my post - I tried that. You can adjust it 2 different ways:
  • Through the "Voice" settings in the NAV/DIC
  • By turning the volume knob while she is speaking directions
I did both and it still only goes down as low as 21.
I realized this recently as well. Why would they have the default lowest volume setting up so high? Startles me sometimes and it's hard to even have a conversation in the vehicle while she's talking. Another GM fail.
I agree guys with lack of being able to turn it down past 21. I actually just turned the voice off so I can still have a conversation and listen to music
Good to know it's not just me. I have an appointment next week for some other issues and I'm going to have them look into it. Also GM Customer Service on these forums has opened a case for me. I also have a phone number for the Infotainment Team and will bug them about it (AGAIN!!)
  • 3 years later...
Any updates on this?  My 2018 won't go lower than 24, which I'm assuming is even louder than 21...  ?
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
