2016 TSB list
I was surprised there isn't a pinned listing of TSB's someplace. Am I missing something? Or is that something you have to pay a service fee on a website to view?
I have seen it quite popular on other manufacturer forums to index the tsbs by Model and year but not give u the actual tsb. Here is a good article from consumer reports. Sounds like u need to pay for a service to get full access if u aren't a dealer. http://www.consumerreports.org/cro/news/2014/04/technical-service-bulletins-how-to-find-and-use-tsbs/index.htm
On the Caddy Forums someone sent me the link to a GM website for the techs to use that has all the TSB's. I found one for my wife's ATS that explained how to stop the rear subwoofer from rattling the rear decklid. I had no idea it even existed, I noticed the rattle but it seemed normal considering how hard the stock sub would hit. So I printed it out, took it to the dealer. They ordered a new sub, secured some onstar module that was in the rear decklid and then added some foam and dynamat. Now the stock sub slams and there is no rattle! Hooray for TSB! Would love to see what is out there for our trucks.
the link I had was just for Caddy's
