So I painted my window trim today black from chrome. I cannot for the life of me get the rear passenger side door to go back on? any tips or tricks? all the rest seem to go on fine, but this one just won't stay on. The clips aren't broken from what I can tell?
Edited by gjernagan16
You could try rolling the window down and looking where the clips are on the molding in relation to the sockets they fit in on the door. They may have slipped on the molding??
Yea i looked at that and they seem to be lined up, I'm thinking maybe i have bent the whole thing open somehow. In the process i messed up the black dip so tomorrow looks like im going to re-dip it and try again haha.
Plastidip?
Yes, if i ever do it again or give advice to anyone i would have rather left them on the truck and dipped them. Just mask everything off good which wouldn't be hard. Just make sure after your last coat you peel off the tape while its still wet so it doesn't try to pull it off when it dry's.
That's why I asked. I would have left them on to plastidip.
Whatever you do, DO NOT remove the tape when it's wet. Let it sit for 30 mins like the can says and the tape comes right off without peeling any plastidip off. The plastidip comes off really clean when it's wet. Paint - remove tape when semi dry. Plastidip - remove tape when completely dry.
Your clip is broken. If you look at the clip in the picture, the dead center of the clip should have a smaller tab on it. I had the same trouble with mine. Luckily I had my chrome trim still and just used the clips off of it. post-54656-147801075863_thumb.png
Sent from my SAMSUNG-SM-G920A using Tapatalk
Your clip is broken. If you look at the clip in the picture, the dead center of the clip should have a smaller tab on it. I had the same trouble with mine. Luckily I had my chrome trim still and just used the clips off of it. attachicon.gif20161101_093213.png
You beat me to it. He is 100% correct about the smaller tab being broken off.
I just re-did it today and and did 3 coats and right after i sprayed the last coat i peeled the tape off and it worked perfect. The first time I did it I waited until all were dry and it didn't work well at all. peeling the tape off wet made it 10x better.
oh ok I had all the rest on so I didn't have any others to look at, it didn't look broken to me but I wasn't sure. thank you. Do you know what they should look like? I will make a trip to GMC and order some.
I did my rear bow tie and pulled the tape off wet after the 4th coat and it didn't peel off cleanly. I waited 30 mins like the cam said for the front and it came off 10x easier and I didn't have to use a toothpick to get all the little crap out.
I waited for it to dry on all my emblems and GMC emblem on the front but I also taped off and left a gap like everyone does. That worked great, but on the window trim I taped them off right against the chrome on the top because there isn't much of a line or anything for the dip to cut itself cleanly. If in situations where you tape it off real close to your line or can, its best to peel tape when its wet. It came off clean as a whistle, I've done it both ways just on the trim this worked alot better.
I also only waited about 5-6 minutes in between coats this time with the trim, where as before I waited about 10 minutes or more between coats, so i'm sure some of your coats before were pretty well dry so that made a difference in it not coming off clean.
Does anybody have the part numbers for the clips? I broke mine as well... all of them...
  • 3 years later...
    JimmyB4
    JimmyB4
  • Who's Online   3 Members, 0 Anonymous, 644 Guests (See full list)
    • Are you going to take long trips in it?  If so, try out the seats in the various trims. For me the lower trim level seats were not comfortable.
    • I have a 2016 that I bought new and still own. I'm around 129,000 miles now. The biggest problem was a transmission failure about 2 years ago around 95000 miles. No warning, just failed while driving down a back road. A reman GM transmission installed and it's been fine ever since. A few other minor problems along the way. I am in no hurry to replace it. It's been paid off long ago and do plan on driving this as long as I can.   I will admit I am leery about all the additional electronics in the newer models and feel that it is just more potential problems. I think there's actually more than I would have wanted in this 2016 but so far so good. I think even if something major like lifter failure happened, it would still be cheaper to at worst, drop a new engine in than buy a new vehicle.
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
