Duramax oil leak
Noticed it passenger side rear on bell housing during my oil change yesterday. Not dripping but definitely some residue and I'm using about a quart over the entire oil change interval. I only started using oil after I switched it to T6. Thoughts?
Sent from my SM-G930P using Tapatalk
It is a common problem. My 2014 was doing the same, as were many others. I noticed mine at about 10,000 miles. I parked on concrete and never noticed much at all dripping, but definitely residue and some obvious oil accumulation there. The fix is not an easy one. I was told the problem stems from a combination of the gasket type and torque on the fasteners. I was told that they have to disconnect the transmission to tighten the top bolts that the tranny prevents access to. Tour GM dealer will do this under warranty, although I never let them do mine because it was a minor problem(a $60+K pickup with a leak from factory defect pisses me off). Im sure if I got some part of that wrong I will be swiftly corrected. I traded my Duramax with 58,000 miles and the drip.
Thanks...someone told me today that it looked like i was burning a little oil on hard acceleration. Hmmm
Naah. You're not burning oil, probably the DPF doing a regen. Mine will smoke quite noticeably when doing a regen if i take off from a stop or accelerate from very slow speeds. It put on quite a show a couple of days ago in 20 degree temps when the regen started. Heck if it weren't for it being white smoke, I would have thought I didn't have DPF on there. Strange though as I don't recall my 08 Dmax smoking like that when it did REGENs, but then again I never had issues with the DPF on that thing, just this 2012 with all kinds of DPF/DEF issues.
Keep in mind also that it was quite common for the DMax's to have leaky tranny cooler lines too, not sure if they ever got that resolved or not but was very common with the 01-10 models. My 08 had it start up at 20,000 miles.
Assembly lube from when they put it together. The RAM trucks are much worse. Mine had some and now it has stopped leaking out at 10k
Thanks for the info colossus. Just gotta schedule time to have the bell housing leak looked at.
I'm only gonna post this for only oily leaks on their 2015 chev. Duramax. Your only worst is at dealer. No way they can tell me they are told by gm people that could that problem. My fight would be only 6000 miles or less then. My truck is on 34000 and still leaks oil or trans.fluid on driveway every night. After 4 times at dealer, out of control. 10 days without a truck or a car(handicap) they think they put out?
My suggestion would be to try another dealer then. One that deals in large volume of trucks would be best. Not all dealers are the same.
I also noticed multiple spots on the driveway around 6,000 miles...crawled under and saw drips coming from the rear oil pan and what appeared to be oil blow-by pushed to the tranny cooler lines. There was a little residue on the bell housing too, but very little. After researching on multiple forums, it could be the rear oil pan (relatively easy fix), or the rear main up inside the bell housing between the motor and tranny (not an easy fix). I cleaned these areas and reinspected about a week later. Mine were definitely coming from the left rear area of the oil pan. I waited until my next oil change and had the dealer warranty it. Just had this fixed a couple weeks ago and the drips have stopped...
What I read on many forums is the same thing my dealer stated...GM simply either didn't put enough sealant, or they didn't let the sealant cure during the build process...they have seen quite a few pan leaks on 2014-2016 Duramax's...
I walked in to my dealer for the 4th time complaining about my oil leak within the rear main. The service worker again asked where I thought my leak was coming from. Finally they put dye into it to track the leak. When I returned with the truck, they FINALLY discovered the leaks. On September 6th I dropped off my truck for the repair. They said I would have the truck by the 9th. Since I am handicapped and need handicap equiptment, I was told there was no way they could get me a rental. However, they did not return my truck for 12 days! After driving my truck the next morning, I. noticed it was not running right, so when I got home I lifted the hood and checked the oil. There was no oil on the dipstick. I had obtained 4 quarts of oil and added it to my engine. As of this day, it still leaks.
I would have gone to the dealer owner with that.. People get nervous when it comes to ADA lawsuits.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
