Air Lift Loadlifter 5000 Ultimate
brians09
Just finished installing the Loadlifter 5000 Ultimate. Took about 3 hours, pretty straightforward as I watched the YouTube video. I got the ultimate since it has the internal jounce bumper and I can run them at 0psi. I have them at 10psi and actually don't mind the ride, it feels better actually! I found a neat place to mount the air filler in one of the bed plugs near the tailgate so I didn't have to drill a hole in the truck. We will see how it does when I tow the toy hauler..
I am not all that familiar with bags. Do you add air manually, is that what the valve is for? We had some airbags on an old van before and it had a button and gauge.
Yes, I add air manually via the valve since I have an air compressor at home. You can however, install an onboard air compressor and switch to fill them while in the cab for some extra $$
I have had them for nearly 2-years and they work very well. My stock pressure minimum is set to 5psi. I have the onboard wireless controller for the compressor and prefer it for being able to make adjustments while going down the road. Great set up and in my opinion I wish was available from the factory..
Looks like you drilled yours instead of using the u-bolts. I put my fill valves in the wheel wells. There was already a hole in the metal so I just had to drill through the liner. I also wrapped my lines in loom and used the clips you have to remove for the bags to secure my air lines. 8f93abd691cec1f8b77ea7c37e927958.jpg3e4d282bd6cb946de20d8ca157981177.jpg
Sent from my Pixel XL using Tapatalk
Nice! I contemplated wrapping my tubes in that plastic as well.
And yes, I didn't want to remove the brake line bracket on the driver side(also because I couldn't figure out how haha) so I did the drill and self tapping bolt "5th wheel" method. I didn't like the look of the u bolts either, I painted them black before installation but ended up not using them.
The only reason I didn't want to put the valve in the wheel well was because I get a lot of snow and ice built up there when I go to the mountains and didn't want to chance breaking it off or something.
That would be awesome to have it from the factory with the psi adjustments made through the DIC screen in the gauge cluster!
I just bought this setup with the Black Friday sale at autoanything. Thanks for the post since I will be installing them shortly.
How much did you end up spending on the black Friday sale, if you don't mind me asking? I bought mine about a month ago and just got around to install. I spent $318 shipped..
I would say u did just fine. I paid $306 and some change after I talked to the sales rep online.
The brake line bracket is pictured as being on the side of the frame rail but on my truck it was on top of the frame rail. It confused me for a while until I figured it out. I just hate to drill a hole in my frame.
In September I paid 335 for the springs and 392 for the Quickshot Single Path Supply kit. I got $100 rebate after the fact for the combo.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
