Another round of mods done on the truck
TJay74
Finally had the time to order and install the GM OEM aluminium skid plate set to my 2016 All Terrain. Would of had the job done in about 15 minutes other than one of the holes on the new plate was off slightly so I had to open the hole up some so it would line up. Not a bad setup though over all, has an opening to remove the factory oil filter and now will make oil changes easier as the metal ones are 2 plates versus the single plastic splash shield that GM uses.
Only thig left to do to the truck now is eventually order the Kicker sub, some Nfab nerf bars and maybe get the chrome window strips blacked out and then all of the chrome will be off of the truck.
15401085_1637393009619907_46121325027197
that looks awesome todd,as i was looking to do that to my truck also.do you have a part number for the skip plates?
X2 here. You didn't want to have them Line-X'd before install? And link to where you bought them?
I've been contemplating these or a longer skid plate cover that reaches the tow hooks.
3 plate kit: PN 23176881
If you have a transfer case shield already, you could also buy separately:
Front plate: PN 23135960
Rear plate: PN 23135959
How much did you have to open the hole up? I have them sitting in a box at home, been debating on test fitting first (and widening any hole(s) that need it) or get them Line-X'd first and then figure it out.
I only had to use the dremel and open up 1 hole, took maybe 5 minutes. They are aluminum so I don't plan on having them coated. I got mine thru the dealer as I get them at wholesale price.
  • 1 year later...
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
