Ok . Do u remove the original seal before applying the new one ? And if u can more pics of ur light how the look finish for some reason I can't see them . They look really small .
Click on the pics and it will open them in imageshack. They were too big to upload. If you can't see them send me a PM with your email and I can send you the pics.
I did not remove the previous sealant. Some of it came out when I was prying out the lense, but otherwise I didn't remove it. the retro rubber becomes super gooey and fills in all the gaps when you squish the lense back into the housing.
First let me say up front that I am old. 53 in fact. I don't get the whole bake your headlights in the oven fad!?!? Never heard of it til now. Does it darken them or what? And....why do you want dark lenses reducing your vision at night? Where I live the deer are thick as phiuck! I've hit one on a bike and one last fall in my car. Not to mention coyotes, drunken idiots and other creatures. Don't get me wrong. I have no problem with anyone doing whatever they want to their vehicle. I don't get it and there is no need that I do get it. Please enlighten me on this oven baking thing you speak of
Also....is it better to get baked before the baking of the lenses begins?
Edited by deweyg63
The baking is just to soften the glue to be able to remove the headlight lense. Then you can paint the chrome housing inside. I did it cuz the chrome lights looked funny on my black truck. It was stricktly a cosmetic thing. As for light output, our trucks use projectors and do not use the housings to project the light. Therefor painting the housings does not change the light output. Removing the turn signal lense does reduce the turn signal output, but I bought REALLY bright LED bulbs and they can be seen just fine. Hope that answers your question. :)
Haha, I probably would have stressed less about breaking them if I was baked...but you gotta move quick to get the lense off before it hardens. So probably wouldn't be a good idea.
Baked my headlights and removed the orange reflector and painted the housing black. It took a lot of effort, but I'm really happy with how it turned out. Sorry for the dirty truck and the crappy pics, it won't stop snowing here.
Good job on them. I am in the process of doing a couple sets of 2016 SLE's and redoing my original 2014 Denali lights. They will be for sale by January.
Did this back in my Civic days with a set of halo headlights that were chrome and I painted black. This was before the headlight retro fad was as big as it was so my supplies were limited which proved to be my downfall with resealing. Lots of fog and later water etching in the headlight, likely wasn't sealed 100%.
Yours look great and clearly you followed the right steps. Good on you man!
Alright cool. I'll try and do this to my old ones. What paint did you use and will it hold up?
I wish there was someone who did this for a living I could just send them too lol
I used krylon fusion. I think it's all in the prep..I scuffed the surface and used adhesion promoter.
Have any output shots? Wondering how much visibility is cut down by painting the reflectors. The signal bulbs of course because you have a projector.
Here are some more pictures of the lights in pieces:
Were you worried about burning any electronics?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,254 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
