I had a system (amp,Subwoofer) installed in my 2016 Silverado LT Double Cab in September of 2016. I kept the factory stereo and had it installed by a guy that's certified in audio installation. Up until 3 weeks ago I had no issues with the vehicle/battery. I tried to turn on my vehicle with the remote start and it wouldn't turn on, I went outside tried to turn it on manually and it didn't turn on. Luckily I have a battery booster pack and I was able to get to work on time. A couple of days later I had the same issue in the morning. So after that I decided to take out the fuse on the amplifier and I went 2 weeks without any battery issues. Yesterday I decided to install the fuse so I could listen to some tunes and by the end of my shift the battery was dead. I know that the remote wire is plugged into the Radio fuse in the dash and I want to know if that is the reason my battery is draining, also if that is the reason why did it take almost 5 months to cause this issue? anybody else having this same issue? any suggestions would be greatly appreciated.
Common issue with the truck. Took mine in a couple weeks ago for the same issue. It's happening to people without systems installed so it's not just you, it's the battery they are using. It's covered under warranty.
Sent from my SAMSUNG-SM-G935A using Tapatalk
I like the custom tweeter mounts, do they allow you to mount the tweets off axis? I ask because I have installed some HERTZ HSK's using the stock location and they sound horrible, I have to have the balance 3/4 to the right or the passenger speaker is mute. I would like to mount them off axis however I have yet to find a good mount / bracket
Those things are beautiful. I tried countless calls and emails to Alpine but customer service would always refer me to parts and parts would never email me back so I don't think they're selling it standalone.
Very easy to make tweeter mounts for stock location using the factory speakers. Factory dash speaker has plastic frame. Just cut the cone away webbing away leaving the flat frame. I cut a lite weight metal washer from sheet metal to use as a spacer when I tried a set of Alpine tweeters in the dash. As has been reported on here prior, having just a tweeter at the dash, cut off it soo high, mids get lost. Seems you need to be somewhere about 500hz and up at the dash location.
The tweeters cannot be adjusted in the alpine pod. Basically there are two slots on the tweeter part of the pod and the tweeters just twist in
  • 11 months later...
You have to cut the rear carpet to install the amp and sub? There is no sub replacement for the under the center console?
I may end up buying the Alpine SPT-31GM kit for my regular cab just for the 3 way fronts and tweeter mounts.  It's expensive at $1000 but I think it may be worth it for a clean install.
  • 4 months later...
Did you end up doing this?
for the most part.  I found the 8'' midbass speakers and 3'' mids with crossovers for both on ebay for a really good price.  I used some regular S series tweeters with them since the specs are pretty close.  I'm only running them off of the stock head unit with the passive crossovers they came with and they sound ok. not a lot of bass. I feel the 8'' need way more power to really shine.  I'm planning on a DSP with active crossovers soon, it should really wake them up.  alpinetruck1.thumb.jpg.d0bc806daa9b99eff8fc57d92c5debfe.jpg
I'm starting to dig into this more and more. I'm pretty sure there is a tear or something in one of my speakers as when it gets loud enough there is distortion from the drivers side front speaker that wasn't there before.
Really like the Alpine setup as it seems an easy plug and play option, and frankly I have a hard time trusting audio installers as I've seen and heard of a lot of horror stories and I don't have the knowledge to vet places.
I understand this alpine kit is expensive, but I'm curious to know what a comparable kit would cost, how much would I save with a diy kit or visiting a quality installer?
Also, for anyone that has heard the alpine system how does it sound? My music tastes vary from heavy metal to jazz so curious to know how this system handles any of that for anyone with the experience.
  • 3 months later...
Anyone know if you can buy the processor for the kicker system standalone I don’t wanna use the sub but need more from the door speakers I’ll be adding my own sub and am
I haven't seen it anywhere yet
  • 3 years later...
I wanted to bump this back up, been several years since anyone posted on this topic.  I have a 2015 Silverado High Country.  I have been looking at the Upgraded 2.5HMI, Radio and Denali Cluster from white media, that all together is around $1400.  It will gret me the android/carplay with all the factory integration.  Before pulling the trigger this time I thought I might see what people have and recommend, if I spend this much on the factory upgrades I might as well give consideration to just junking the BOSE.  If I have read everything and understand it, since I do have the BOSE, I would need to replace the Headunit, bypass the amp and install a new one and upgrade the speakers/sub.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
