Installed my catch can today and wanted to post a semi install thread as well as my impressions on this kit since I haven't seen anything about this can yet. I purchased the UPR dual valve Catch Can with clean side separator mainly because I have always had great luck with UPR products in the past and I absolutely love the braided hose with oem style quick connect fittings. Pricing is on par with Elite, this kit ran me $400 shipped to my door including the clean side separator.
First off, I did have a slight issue with the kit (missing hose) but UPR made it right and shipped the missing hose the day I called and had it to me in a day. Install was a breeze, everything fit perfectly with absolutely no issues. This is a seriously high quality kit - everything from the machining on the bracket, finish on the can itself, and the high quality hose and fittings is top notch. All hoses are assembled with push connect fittings and oem fittings, no hose clamps, and are already assembled to the correct length. Check valves are included, I chose to upgrade to the pro series check valves only because they were out of stock of the regular ones and I didn't want to wait. The can also has a ball valve on the bottom for easy draining.
I'll let the pictures speak for themselves but bottom line is if you have a stock intake this kit is as good as it gets. I did speak to the UPR guys about going to an aftermarket intake later on and they said they can supply the hose and oem fittings to adapt to whatever intake I chose so the kit would still match.
Install pics:
AF4B201A-5055-4131-AB7D-CBAA6D214A1D_zps
958142F3-72EE-4FA6-9A57-A46720BB9DA3_zps
D16A958B-B52F-4473-B0D9-C2B25C97C227_zps
A6012014-0A81-4B19-91FF-456698F8096A_zps
AA0EEB66-DB32-456B-A60A-638B8B508764_zps
EE215B1E-8272-4DE1-9761-FA0FAA265E77_zps
401FD609-5719-4C7B-946C-A40990552256_zps
FC2E1FEC-36D8-4742-B301-D489E83B41B3_zps
Very very expensive. I come from Ram 1500's with Hemi's and catch cans for those trucks ran roughly $100.
Looks real good though I have to admit. What is the can mounted to? Something near the brake booster?
It's mounted to an aluminum bracket that bolts to the brake master/booster stud. 90 degree bracket.
Sure, $400 is expensive for a catch can but it's comparable in price to the Elite which everyone seems to run. By the time you buy the top end Elite and upgrade to braided hose it's the same price. This one comes with the factory style quick connect fittings which in my opinion make it a bit nicer. I'm a sucker for a clean setup and since I'm running the factory intake it just seemed like the best choice. UPR makes great stuff. Ran their suspension components on my fox bodies back in my drag racing days.
I love the setup and clean look. And you are right having the braided hoses and quick connect ends is super nice. Do you have a link to that whole kit? What is the capacity on that can? Did you connect a hose to the bottom of the can to drain?
Edited by AllTerrainX
Also the side separator replaces the oil fill cap? Thats neat, never seen that before. What advantage is there to that? I am new to catch cans and looking for something for my new truck :)
I did not connect a hose to the drain yet. Seems there's plenty of room to get a bottle or pan to drain into so I really didn't think about it yet. The valve has npt threading so a simple pipe nipple and rubber hose could be added. The can is 12 oz capacity according to UPR.
Here's the link to the kit I purchased. They also have the same kit without the clean side separator, $100 cheaper I think. http://m.uprproducts.com/chevrolet-gm-billet-oil-catch-can-dual-valve-css-silverado-53-14.html
The clean side separator isn't super necessary, Elite has one as well, and is mainly to catch the little bit of oil mist that is returned with no manifold vacuum (wot). Basically if you run the truck hard it may be worth it but really I figured why not. Adds a little dress up to the engine bay and matches the whole kit and can.
Only for the 5.3? I followed the link and did see anything for the 6.2
I think it's 5.3 only. Not sure what the difference is but I'm sure it's just hose length/routing. I'm sure they could get you setup with something to work if you called or emailed.
Kinda figured that.... loving the kit looks good
This is Joe the owner of UPRproducts and our kits are available for both the 5.3L and the 6.2L trucks. I have just been waiting until now to become a vendor since we have finished the final components to make all the Introduce the NEW Plug n Play™ UPR Catch Can Systems. Our goal was to offer the most comprehensive OEM style loaded catch can system, with braided lines and Plug n Play™ fittings. Feel free to me for any questions.
Joe M. - UPRproducts.com
After much searching online for a nice catch can set up, I went wth this one. I bought this kit for my 2016 5.3 back in early November only in black. This kit is definitely top notch, looks great under the hood, and it just doesn't get any easier to install. The factory fittings on the hoses really make this kit look top notch professional. UPR has great customer service, they respond quickly, and will help you with any problems or concerns you may have. This kit has been functioning great since I put it on, and has caught a lot of oil already that I don't want going back into my intake. I definitely recommend this catch can set up to anyone thinking of purchasing a catch can. I would buy. This kit again. Money well spent.
I will have the part number listed tomorrow for the 6.2L kits as the difference between the 5.3L and the 6.2L trucks is the location of the clean line. The 5.3L has the clean line connection at the rear of the driver side valve cover and on the 6.2L the clean line connection is located just above the throttle body. I'm offering an introductory special through GM-Trucks forum only. PM me for details.
Happ New Year, Joe
Happ New Year, Joe
Joe, awesome news for the 6.2 guys and anyone who wants one of these awesome kits. Thanks for posting!
Happ New Year, Joe
Joe any special pricing for the 5.3L kit?
    • I bought belts and pulleys for my '20 L5P at Rock Auto a couple years ago. I have used them for many years, and almost always save significant money, especially when I buy maintenance stuff ahead of time.   They carry many OEM parts, which is all I use unless an aftermarket is shown to be same/superior, or if it is an insignificant part or unavailable OEM part anywhere else. RA is usually lower priced, often by a bunch, but parts are sometimes unavailable or out of stock, and I do shop around and sometimes find better prices at other sites.   Be aware that you pay shipping, and if you buy multiple items and they are coming from different warehouses, the shipping can kill the advantage. Planning ahead is best if possible.   If you have a transmission service in the near future, check out their OEM (AC Delco ULV) fluid, usually MUCH less than anywhere else.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
