wires through the fire wall
hello everyone,
i recently put led light pod and a led light bar on my truck and was wondering where i can run the wires for my switches through. Right now i have them through my door jam buts its ugly to look at. Any ideas??
hello everyone,
Here is an excerpt from the Kicker VSS Subwoofer install. It explains how to get the power wires through the firewall.
If you need to get circuits to the door panels, I can provide with the terminal pins info to get it from the under the dash to the door panels.
I ran my LED light bar wires through the grommet like "pgamboa" posted on that instructions sheet.
Ditto as the others for my amp wiring.
To make it easier use bailing wire or a wire coat hanger to feed the wire through the outer and in cab grommets.
