Tow Mirrors
azsheepdog
Hey guys....got my 2500 HD gasser in sept. It came with color match stock mirrors. I want to upgrade of course for safety. The dealership just told me that they can install the mirrors but nothing will work on them. REALLY!!! Anyone in Az know a place I can go get them installed and have all the lights and heater work? Or am I SOL....
Thanks in advance.
I would recommend the previous gen style mirrors if possible. I liked the new mirrors, the visibility seems a bit better than the older style, and the rear facing LED lighting was cool, but the blinkers in the mirrors were so bright and blinding at night that you can not see what you're turning into. If they can hook up everything except the blinker in mirror feature, do that, otherwise get the older style. My 15 1500 NHT had the new style, and my 15 3500HD has the older, it's so nice being able to see where I'm turning at night again.
Check out the chevy accessory page http://www.chevrolet.com/silverado-2500hd-heavy-duty-truck/accessories.html
and find a new dealer. Yes these babies will set you back 625 for the black and 100 more for chrome. If your current mirrors are heated, and power fold, and have turn indicators then those functions should work just fine. As for the spot lights - there will need to be a switch installed in the center console for them. That could be easier than anticipated if the wiring is already present - which it might be.
I have a question on tow mirrors. I have them and thought the rear spot light was supposed to illaminate when in reverse. This only happens if i turn on the rear light/bed lighting switch. Am I missing something in the programming that can make this automatic??
I have only played with them on the dealers lot. There they only turned on with the switch and not tied into the transmission at all as the truck was not running and in park. Finally found it in the owner's manual - the cargo and mirror lights are on the same switch - the cargo light only works in park, the mirror lights operate in park, neutral, or reverse. The indicator light on the switch will light only when a light is active.
OK, I found the parts and harness to change everything out. Looks pretty straight forward...Has anyone actually done this yet...or will I be the first?
A good couple hours of work. You would not be the first to do them.
I take you have found either p/n 23372181 (Chrome) or 23372182 (Black) for the tow mirror kits. What numbers do you have for the harnesses?
You will have to remove both the front door panels, and the factory mirrors. The dumbest piece you will deal with is the top black trim that wraps around the top inside of the door. The harnesses themselves are not bad.
I found a video on YouTube for a 15, I'm assuming its all the same steps as long as gm hasn't changed much for my 16
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
