Gun Safe
noway
I want to replace the lock on my gun safe and need to remove the access panel on the back of the door. How do I get these black tabs off? I wedged a screwdriver under them to pry them up and they were STUCK on there. I didn't want to use too much force and break them off if that's not the proper way to do it. Any ideas?
Use a panel clip pair of pliers looks like they just pop out
Sent from my Z981 using Tapatalk
  • 2 months later...
So what was the finding? They look like two piece panel fastners used in auto applications and replacements are readily available.
