How do you drop the transmission pan
The first thing anyone should do when trying to change the transmissino fluid is to try and get those friggin' torx head bolts loose. Greek, I also could not get mine loose. Nor could I get the drain plug out (I was even prepared with a new one!). I ended up dropping my y-pipe enough to dump the pan. I have never, ever been so irritated with any other procedure on my truck. What were the GM engineers thinking when they designed that system??!! That drain plug is barely big enough to get a socket head on it, let alone grip it enough to turn (I'm sure GM used a heavy duty thread sealer). You have to be a contorsionist to get to the torx head bolts.
Ok, enough whining.... :thumbs:
This past weekend I crawled under the Yukon to see how hard it was going to be to drop the Tranny pan.
I used a T-40 torx on a 3/8" drive ratchet and the 2 bolts holding the shift cable bracket were no sweat to loosen, removed the back bolt and swing the bracket back out of the way.
all of the bolts on the oil pan are clear and easy access.
This is will be no problem to change the filter & fluid. Actually its a piece of cake compared to my Jeep Cherokee & Grand cherokee.
  • 1 year later...
I attempted to do a filter change this weekend. What a PITA.
I completely rounded off the drain plug bolt. I don't think its ever been moved, and now it isn't going anywhere. Took a bath in trans fluid trying to drop the pan, only to find I couldn't get the pan off due to the &$(#) shift bracket.
The previous owner must have taken the truck off roading, because there's a bit of mud in corners of the truck, including in the torx sockets up top. I'm reluctant to try and losen the bracket bolts because I can only get one hand up there and if the torx bit isn't completely centered, I'm afraid I'll strip out the inside.
I ended up tilting the pan enough to get the filter on and slosh out most of the fluid, but I had no other choice other than bolting all back up again. Of course, now the pan gasket leaks and some of that mud no doubt made its way into the pan when I was wrestling with it.
My only other alternative is to remove the trans Y-pipe, but frankly, I don't want to snap off an exhaust stud. I hope some GM engineer's ears were ringing over the weekend, 'cause I had some real pointed words for him/her yesterday.
BTW, I have the factory service manual. Doesn't mention anything about the interference, just says to remove the pan bolts and drop the pan. Sounds real easy!
I'm no engineer, but it seems like a torx screw is a bad idea pointed up to collect debris and in an area where it has to be removed blind in order to accomplish a standard maintenance procedure. A regular bolt should have been used on that bracket.
OTOH, the recessed pan drain bolt would have been a perfect place to use a large torx. Instead they used a shallow hex made of soft metal. I don't get it.
I feel your pain...I am getting BG flushes every so often at my local garage and following up with a drop the pan and filter change at the dealer. Still trying to figure out how the dealer is dropping the pan. They must be dropping the cross pipe... :puke:
When I drop the pan on my 4L60E I just use a c clamp and clamp the shift bracket up against the front drive shaft. This gets it out of the way and its simple to drop the pan without messing with exhaust pipes. use a large screwdiver to carefully bend the shift bracket back into place after you put the pan back on. I stripped my drain plug too, thing wouldn't budge.
i installed a drain plug in my pan. it was 5 dollars at any auto store. i crawl under and 5 quarts of fluid are drained out in about a minute or so.its that easy. i do it each year,in goes5 or 6 new quarts. i change the filter about every 35,000.believe me they are not that dirty if any. very little in them.when i do this i drop in 5 quarts, drive for 3 days to mix and then drain again, drop in 5 more new quarts. then every year drain and add 5 new.its quick.this has worked for me and i have gone 150,000 and never had a transmission go.also cooler is a must. take care :D
  • 3 years later...
Is the tranny HOT when you guys are trying to remove the bolt?? Seems like that would make it easier? I am getting close to doing something on my Silverado, since everyone is having trouble dropping the pan, I thought about just removing the drain plug and changing the fluid every 25,000 miles and tackling or getting the dealer to change the filter every other time which would be every 50,000. Not sure what I am going to do yet, with so many people having probs with the drain plug too, I am not sure what to do? Wish it was a 700R4, I can drop the pan and change the filter in my dads '91 K1500 in no time at all!
This thread was started in "2003", I'm sure the bolt has been out for some time now.
Don
  • 3 years later...
I wish I would have found this thread before I attempted to change out my fluid and filter. I rounded off my drain plug as well. I bought a new one and tried dropping the pan. After about 2 hrs I was covered in ATF and my garage floor was a mess. Not much fun on one of my only days off with my little ones asking" are you done yet daddy?" "We miss you". I gave up, bolted the pan back in place and put fresh fluid in with an old filter. $100 later and an hour at the dealer and I have new fluid, filter and drain plug. I'm glad I wasn't the only one with this problem. Its super frustrating.
Good lord, I had just graduated high school when the original post was made. This thread is olllllld. :lol:
All you have to do with that braket is move it 1/4-3/8" with a pry bar. It's easy. You don't even have to bend it back.
Mark
    DaleB
    DaleB
  • Who's Online   5 Members, 1 Anonymous, 1,530 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
