Programer or not
Rme2513
What small add can I do that would actually make a difference I've have seen on here people talk about programmers and say it makes a difference but then they say 0 to 60 in 6 sec well I'm bone stock and can do that
There has to be something simple to bost the torque some ?
The tuner/programmer will be one of the best ways to boost power. Intakes are usually pretty good too.
I would Tune and do an intake such as aFe. Convert to E85/93 Tune for even more power (will be a little costly to be E85 compatible). I plan to do these things to mine in a couple years.
PS man I just love the sound of the 6.2 especially when you get up 80+ mph she's still pullin hard and the engine is just screaming!!
im the opposite the engine sounds like it's got another 2k in it but I'm sure a lot of parts swap would have to be done for it to be effective
The L83 and L86 engines are severely neutered by torque management. These engines have high compression and seemingly huge power ratings, but you cannot feel it until high RPM. You need at the very least an aftermarket tune to reduce the torque management and knock retard to feel what these engines can really do. Cheap investment is s Diablosport tune. Turn off the torque management, and adjust the other available parameters and you will have an entirety new truck! I was embarrassed to drive an eviboist before, and feel it's power off the line, but now my 2005 5.3 feel like it should, rated at 355 HP. And I still get better mileage than an ecoboost. 20 mpg is no s normal expectation, and it sounds great, like a V8. Which it is.
power off the line is good you have to baby it just so you want spin I'm looking to improve the 30 to 90 time I would have to put drag slicks to actually be able to floor it off the line if your spining your not going anywhere
Anyone have a superchip or diablosport programmer on a 6.2
