I recently finished up my Bose Subwoofer replacement in my 2016 LTZ. I felt the Bose Sub was very underwhelming. I considered the Kicker option made specifically for the Silverado, but didn't want to give up the floor space. After removing the center console and lots of measuring, I came up with a box design to work with the JL Audio 8W3V3-4 8" sub. This sub requires a volume of 0.30 cf. short of making a fiberglass box, I'm convinced there is no way to get any more volume from a box that fits under the center console (with no modifications to it).
I added an Alpine MRV-M250 amp to power the sub and mounted it on the back wall next to the factory amp. Also got the remote for the amp which is mounted inside the large storage compartment of the center console.
It sounds absolutely amazing, exactly how the factory high end system should sound! You can feel the bass in the seat, something that never happened with the stock sub!
Here's a few pictures.
  • Like 16
Yes please give more info! Such as the exact dimensions and also some pics with the console mounted back into place and how it looks!
Our trucks comes with a subwoofer???? where is it located?
Only the bose systems do
Sent from my SM-N920V using Tapatalk
I just looked and I don't have the Bose system. Do I need the bose system? Am I missing anything? lol I only have 6 speakers.
LOVE IT. Waiting on my audio control LC2i to show up and I'm going to tear in. Care to share box cut list/dimensions so I can prebuild without tearout?
I have the bose radio, where is the factory sub located. Is it in the console
Under
I didn't include any pictures of it all back together because it looks just like it did before I took it apart! The center console fits over the top of my box just like it did over the bose. There's no way to tell something different is under there until you turn on the radio!
I will post the dimensions once I get a chance to draw it out, hopefully tomorrow.
Here is a picture of the stock setup. The Sub is not even 6"! And the box is ported, I guess I was under the impression it was a sealed box.
Well thankyou for taking the time and effort to take pics... seconed.... how much for a box shipped to california...
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 681 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
