Are there any options for a hidden winch mount or a brush guard / winch mount that utilize the factory bumper for a 2017 Sierra 1500? I've found several options for the 2014/2015 but nothing for the 2016/2017.
Andrew does your truck have the license plate spot in the front bumper? I put one on my 2011 Silverado built it with 1/4 angle but later Rough Country came out with the same style set up. Uses the license plate area for the rollers. Im guessing you looked there? I picked up a plate of my liking and bought a clamp kit on ebay that you put a license plate on and it snaps on the rollers. Just noticed were both in LR. Cool If you really want to do it find a 2013 and measure between the frame and compare to yours. If its the same you could use the rough country kit. There kit says it goes from 07-2013.
Edited by crankman
Thanks - I'll definitely check it out. I really wish somebody would develop a kit for this - I'll gladly throw $$ at them.
Here is mine. I will be posting more pics in the next few days with the brackets I built and plate setup. No one makes a bracket for a hidden winch because of the tow hook bolt placements. All brackets and plates were made of 1/4 inch steel. I did have to drill one hole and run a 4 inch bolt through the passenger side frame, rear hole of the tow hook for the bracket bolts. I also had to cut off the lower front bumper brackets. The winch was to wide to sit between them so they had to go. The last major mod was the lower facia being cut. The fairlead sits right below the metal of the bumper and I cut out the plastic of course. I also cut the plastic to fit a receiver and we welded a small piece of angled steel to the bottom of the winch plate and used the original screws and retainer nuts for the facia bracket. Last, Oregon requires a front license plate. So I used 1-1/4 conduit holders, drilled holes in the license plate and original plate bracket, and it just simply snaps onto the fairlead. Completely hidden. Winch is a Badlands ZXR 12,000 with wireless remote. I am unable to to to the spool lock, so no free spool for me on this setup unfortunately. I also ran quick connects 1/0 AWG wire to both front and rear of the truck. I will also be doing a hidden winch on the rear factory bumper of the truck in the coming weeks.
Edited by Will O'Daniel
Driver side bracket. You can see that the bracket hugs the frame. You can also see that the bracket drops 1-1/4 inch and pushes forward so the the plate can clear the complex angles of the plastic facia. The passenger side is a mirror of the driver minus the extra hole for the to seat the inside bracket to the frame.
Passenger side bracket. You can see the “odd” bolt that we used to pass through the back of the tow hook. This is a 4” bolt. We bored out the threads on the back of the tow hook so it could pass through and drilled a hole in the frame on the other side. This is the only frame modification needed.
  • 3 years later...
Have you guys found the Rough Country Hidden winch mount?
https://www.roughcountry.com/gm-hidden-winch-mounting-plate-11004.html?find=2017-gmc-sierra-1500-4wd-739475&sid=IyuyamO9di
I do have a few questions about it if anyone's installed it. Do you have to relocate the control box with this? Do you reach through the hood to disengage the clutch?
Thanks!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
