Want LED DRL's in my 2015 Sierra
maxum3300
As the title says I want LED DRL'S in my 2015 Sierra. I'm considering buying these.
https://www.diodedynamics.com/store/catalog/product/view/id/22545/s/2014-2016-gmc-sierra-switchback-drl-led-modules/category/1451/
They require opening the factory light to install these. Has anyone done this? Also at the bottom of that link it has the installation instructions and show how to remove the factory LEDS and drivers. If I had factory LEDS I wouldn't need this kit. Do they factory lights have led drivers even though it doesn't have leds?
That kit looks like it turns the led drls in the 14-15 SLT/Denali into turn signals as well.
Sounds like you have a base/SLE and want the SLT/Denali lights?
I may be interested in selling my 15 SLT headlamps once I install my 16-17 ones. I think they would be able swapped without any modifications.
Can you post pics of your headlights with the leds? I didn't know any 2015s had leds. That clears up alot of confusion for me. In the installation video it shows they remove the factory LEDS and replace them with the ones supplied in the kit. My question is will this kit work for trucks that have no LEDS at all? Also how much would you want for your old lights and how can we confirm they will work in my truck. You are correct I have a non led SLE.
There is a module that mounts on the back of the headlight assembly that controls the LED lights on top and bottom. Otherwise as far as I know, the headlights themselves should be interchangeable. I also have a set of SLT/Denali headlights with the LEDs that I removed that I could sell if interested, but I'd let the first poster go first. I bought an extra set when I did my HID retrofit and put those in. Haven't had any issues with them in two years, so no reason to keep the others now.
Any way to confirm whether they will work in my SLE or not? According to this post there is a harness that is needed and a BCM program by GM. How much would you want for the headlights with the LEDS? Would you be willing to let me return them if they didn't work in my truck?
Forgot to post the link to the thread that says it won't work.
http://www.gm-trucks.com/forums/topic/153974-swap-2014-sle-headlights-for-slt-w-leds/
We could probably compare the connectors on the back of the lights. I would assume add long as mine match up to what you have it should work. After all, if the module is mounted on the back of the light assembly that should control the LEDS.
Well I guess if there's any way you could pop one of the headlights out (grille, along with top bumper trim has to come off first I believe) and take a look at the electrical connector and count the pins that it has, we should be able to figure out if it will work. Based on that other post you linked, it leads me to believe that your harness may have one or two less wires going to it. Probably to control the leds/drls. If that's the case, it may be complicated to add the SLT/Denali headlamps to your truck.
As for price, I'm not sure yet. I'm still waiting on my other new one to come before I even take them out.
Harness for 14/15 SLE to run 14/15 SLT headlights:
http://www.gen5diy.com/GMC/Sierra/NON-SLT-to-SLT-Headlamp-harness/
I also have a set off a 2015 SLT for sale lol.
Sent from my kayak
Here's with headlamps and both leds on:
574CAE33-E00A-44CF-B059-52E073BF1172_zps
Here is off (looks a little better than the sle ones with nothing in those spots):
5C0B4573-F985-4FE2-B7F6-1FA9F7798A66_zps
It doesn't look like I have any pics of just the drls on, but I'll try to take a pic of that today.
Harness for 14/15 SLE to run 14/15 SLT headlights:http://www.gen5diy.com/GMC/Sierra/NON-SLT-to-SLT-Headlamp-harness/
Sent from my kayak
Thanks for the info. Looks like it's doable with that harness. A bit pricey. I guess it will depend on how much you guys want for your SLT lights. PM me your asking price. If it's reasonable I'll give that route as opposed to the diode dynamic aftermarket setup. Not sure how I feel opening up my factory lights. Let me know prices guys. Thanks.
I won't jump over these guys that have some for sale. You can probably make your own harness, I'm sure its been done by someone on here. It would be a lot cheaper, trust me. I bought one from gen5 for a lot more than you can buy a home made one lol.
I did the Diode switchback setup but you do need the OEM headlights with LED DRL's. Doesn't require a harness but you can use one if you want the LED's to behave like OEM. I didn't do the harness.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
