Tires
So my Method Wheels +18 offset are officially here and i've been searching for tires. I really am leaning towards the Nitto Ridge Grapplers in 285/65/18. I have a 2in leveling kit on the front. Do you think that is a good size to go with? I found them for $1,059 free shipping. I just wanted to get some thoughts on this before I pull the trigger.
I also like the Toyo AT2 they are $1,079 but I hear the ridge grapplers are a lot nicer.
I like those Nittos. Here is a pic I snapped off a truck locally.
Sent from my SM-G930V using Tapatalk
True. I like the nittos and the toyos as well, but considering they are similar in weight (when looking at LT toyos), I like the Nittos a lot more. If the ridge grapplers weighed as much as the trail and mud grapplers and MT/RT toyos, then I may lean more towards the AT2s.
So.
Given aesthetic appeal and weight, I am favorable of the ridge grapplers.
Looks like he's got quite a bit of room. I wonder if I could go a little bigger
I think those are 275/65/18. Yours would be a tad taller.
I have Toyo Open Country RT they are the best tire I have ever had. I can't believe how dead quiet they are and ride very smooth. They really do not feel like an E rated tire.
I really like the tread design of the Toyo RT. They're just so gosh darn heavy. I'd rather have a 60lb ridge grappler over a 70lb RT, more due to keeping unsprung weight down and mpg up (somewhat). Not so much because of the ride/noise.
And one size wider.
I plan on installing 275/70/18 which are E-rated, but a true 33". 285/65/18s are good as well.
I'd look into the BFG KO2s. The Nittos look just like the stock DuraTrac.
Where did you find the weight of the Ridge Grappler I haven't see weights on the web site yet
Shipping weights provided by tire dealer(s).
Toyo's are on their website (nice and convenient), but for some reason Nitto doesn't publish them, and I couldn't get Nitto customer service to respond to my weight requests.
I went through some local Nitto retailers (including Discount Tire, online (DTD) and in-store) and they all said roughly the same weights.
305/55r20 XL Nitto G2 is 50-52lbs
305/55r20 Nitto Ridge Grappler is 60-62lbs
33x12.5r20 Nitto Ridge Grappler is 61-62lbs
The variations were in 4 different tire shops answers but they were all in the same ballpark so I don't feel like they were ALL bs'ing me since all their answers were fairly lined up, ya know?
I don't have weights for the 35x12.5r20 Ridge Grappler, as I was shopping in the 33 range, so I hadn't asked for the 35. You could always go to Discount Tire Direct and do "live chat" and ask them the weights.
And one size wider.
I just think the ko2's don't look as good as the ridge grapplers
I have the Toyo at2 in a 285/75r18 on stock wheels and love them. Measures out to a 34.8 x 11.50.
I love my RT's but they're not as quite as I thought they would be but they're not bad at all for 35s
Sent from my Nexus 6P using Tapatalk
Do they rub? What leveling kit do you have? I can't figure out what to do. With an RC 2in level will 285/70/18 +18 offset rub?
Go big and put on 295/70/18... guy just traded a truck in at my dealer with a 2.5 rc level and that size and I didn't see anything rubbing
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
