I'm currently installing some towing mirrors on my 2014 Chevy Silverado LT that have the turn signal in the mirrors and my truck previously did not have turn signals in the mirrors. I'm looking for someone who can hopefully tell me how or point me in the right direction of how to get the turn signal to work on my new tow mirrors?
Thanks
Thanks
Hey there. Your tow mirrors will have Turn signal, Cargo Lamps, and Park Lamps. On 2014 LT trucks, GM did not add the circuits in the door hinge for the Park Lamps and Cargo Lamps. In most 2014 owners I've helped, it seems that the turn signal circuit is present. If that's all you want, you can tap into that circuit. If you want Cargo and Park Lamps, there will be a little more work involved. This might help.
  • 3 years later...
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
