2017 6.2L 8 Speed Tuning
rzpalm
1 minute ago, SILVER SLED said:
No I haven't.  It's actually $599 and it runs and shifts pretty good and I don't plan on drag racing this and getting every little 10th out of it.  So I haven't bitten the bullet yet.
I tried the T87 swapped in place of my T87A, but it didn't work. I have a Magnuson supercharger on the truck right now, and the downshifting is poor, so I might do the HP Tuners unlock and tune. That'll be $200 to unlock and then the 4 credits that I have left on my handheld.
  • Replies 98
Well if you were closer Id have you do mine.
  • 1 year later...
3 hours ago, John Walker said:
What’s the best tuner for my 2017 Silverado 6.2?
Kind of a loaded question but for a stock truck you can get a blackbear or diablew tune. Or Get HPTuners and have someone send you a tune or learn yourself. I’d recommend looking into CJTUNES E85 sensor kit, too.
The CJ costs so damn much though.
The harness is already under the truck and the sensor for an impala is like $30. Couple fuel connectors and blahdow I got flex fuel for $50 bucks.
Yes there are cheaper ways but this is one very simple way. They have good write ups and info if nothing else.
For sure it's a simple kit, no doubt there. it's just about $200 too much for something like that is all lol.
I mean c'mon, $315 for a modified sensor with fittings and a harness extension.
Well i'm lazy and spend too much for ****** on my truck so its perfect. I didnt even look into how much it would cost to buy the sensor and build the harness extension. Times are tough. Trying to help out a small business haha
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 507 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
