Italian tune up
I do this as a free service on almost every car I road test at work lol
  • Replies 35
And all this time I thought an Italian Tune Up was just a good ass kicking.
This is hilarious! This comment made my day!
I'm Italian, my relatives are Italian, my friends are Italian.........I've heard plenty of stories about Italian "tune ups" and they have nothing to do with motor vehicles. And it might not be such a good idea to walk up to the wrong person and ask for one!
Back in the '60s, Ferrari was using Weber carburetors on their engines. Weber's were great for high performance engines because they could be individually tuned for each cylinder and they could dump a ton of fuel into the engine when you stomped on the gas. The only problem was that you had to constantly fiddle with them to keep them in tune and if you didn't drive the crap out of the car, you would get carbon build up on the valves because of a rich fuel mixture under light load. The mechanics would recommend that you drive the crap out of the car (like a Ferrari should be) to loosen up the carbon. They called it an "Italian Tune-Up" since this method was so often used on Italian cars using Weber carburetors.
  • 3 weeks later...
I second the catch can. Installed my elite engineering e2x catch can at 4000km and its at 15k now and ive emptied it 3 times and everytime has had oil/gas/milky condensation come running out. I would highly recommend the elite engineering e2x. However, everyone has different opinions about them, I can see from experience it DOES prevent crap from getting in the intake. Also you get what you pay for so don't complain when the $50 homemade one only catches 10% of the gunk.
  • 4 months later...
In my company we have quite a few 2015 5.3 silvy's and a few are getting close to that 100k mark. When I run into the guys that drive them at meetings they have not had any issues out of the truck except for the low ground clearance which my company fixed by adding 2 inch spacer kits to them. Of course due to the spacer kit and the extreme conditions we drive our company trucks in most of these have had to had ball joints replaced more than once. My company has always advertised the specs needed and let local dealers bid for our business (buying 30+ trucks at one time each year) and the lowest bid gets it. That may change because half ton silvys just can't handle the areas we drive into because of the low ground clearance and ford is not much better so for us it may be a dodge or toyota half ton or bump up to 3/4 tons and take the mpg hit.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
