Italian tune up
Which will help keep your injectors, pistons, cylinder walls, and exhaust values clean but will do nothing for intake valves.
:driving:
http://www.toptiergas.com/deposit-control/
4.3.1 Intake Valve Keep Clean Initial Performance Standard.
4.3.1.1 Test Method. Intake valve deposit (IVD) keep clean performance shall be demonstrated using ASTM D 6201, Standard Test Method for Dynamometer Evaluation of Unleaded Spark-Ignition Engine Fuel for Intake Valve Deposit Formation. Tests demonstrating base fuel minimum deposit level (4.3.1.2) and additive performance (4.3.1.3) shall be conducted using the same engine block and cylinder head. All results shall be derived from operationally valid tests in accordance with the test validation criteria of ASTM D 6201. IVD results shall be reported for individual valves and as an average of all valves.
  • Replies 35
I feel like some people dont understand the difference between port and direct injection.
Even after the video below; MOST will STILL not know or understand the difference.
Sounds like it may not be the sky is falling for most GDI engines.........
http://www.autoguide.com/auto-news/2015/01/is-carbon-buildup-a-problem-with-direct-injection-engines-.html
Additionally software plays a huge role. “What I think is most overlooked is the PCM calibration itself,” the engine-control computer.
“I believe it’s the absolute key to preventing the bulk of this buildup by making the air and fuel burn as completely and cleanly as possible.”
Im sure someone on this form could chime in on valve build up, Do a search on this form im pretty sure i read about it being problematic for some, but i could be wrong. So with the very poor tune these vehicles come from the factory with i highly doubt they have the proper ecm calibration. Were getting off topic.
I'd like to see the science behind how letting the vehicle run at 3-4k rpm for 20 minutes builds up heat on the intake valves. You'd certainly be at a very low throttle position just cruising along.
They said 400 degrees celsius, that's seems really hot for some intake valves.
But I will say that should definitely work if you can get it there, I mean thats exactly what an oven does on self clean. It turns carbon deposits into dust, and they are usually at 400-500 degrees C
I never even heard of the Italian Tune Up until now. Interesting.
I'm Italian, my relatives are Italian, my friends are Italian.........I've heard plenty of stories about Italian "tune ups" and they have nothing to do with motor vehicles. And it might not be such a good idea to walk up to the wrong person and ask for one!
Lol my wife is 1st gen off the boat Italian. I ask her about it and she got a good laugh.
Yes if you can get them hot, its worth a try certainly cheeper than a manual cleanig
This right here is spot on...
There have not been any problems, a few people have shoved a camera down there or taken off the intake and seen a little build up and started making a mountain out of a mole hill (all catch can supporters) but it is minimal.
Truth is this is not a problem and those few that people heard about and get the scares from (the Audi's and VW's mainly) is partly due because those engines were not designed with DI but rather adapted to it.
Everything I have read from the designers and engineers/builders stress how important the calibration is for how long the valves are open, when they are fired and so forth are the biggest players in preventing build up. It isn't so much the air coming through the intake as the gasses and exhaust from the cylinder itself.
This has been known about for well over a decade and they design for this accordingly. They aren't going to put 100k warranties on the engines if they start running like crap and need a deep cleaning because of how they are designed at 60k miles, it would be too costly. The put millions of miles and hundreds of thousands of hours on the engines in testing before we even see them, don't you think the issues would have popped up?
These engines aren't tuned horribly from the factory, they just aren't tuned for all out performance. They are tuned for reliability, good power, mpg and NVH which they accomplish. And that tune needs to be balanced now with optimizing combustion chamber activity to minimize any possible build up. So to say these come with a poor tune up is just flat out wrong, it just isn't optimized for power (which is what probably 99% of people who get a tune go for) and crisp fast shifts as that reduces longevity which a manufacturer has to warranty. And the tune you are talking about could very easily make build up worse...
This is such an in depth subject with tons of on it. I can see how running the vehicle hard will help, even just going full throttle and allowing the added air and heat to remove some stuff can help. The idea of heating the valves that long that hot would be interesting, and I know these engines go through a test like that at full throttle for a long period of time so it certainly can't hurt.
Tyler
Since I'm Polish...what kind of tune up would I need?
Everything I could think of would be way too bad to put on here
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
