On 5/9/2018 at 2:36 PM, b-garage said:
I have a 2018 GMC Sierra Denali, what did you have to modify to make the 2500 HD hood fit the 1500
Edited by Eric Washington
Thanks
On 12/14/2018 at 4:15 AM, Butch Rynearson said:
I want to find a used 2017 hd hood & hinges just for looks alone. For my 2015 gmc sierra.I don't want the under hood air box.I want to do this as cheap as possible. What's the least amount I can get away with?
Honestly it depends on the junk yard.
Bro love the rims. Very nice. Love the truck period but still nice choice.
The body shop had to get the 2500 hood springs. That hood is heavy compared to our old 1500 hood. Despite what some people have said that’s all. Will walk outside right now & take pics under my hood for u.
Whats up guys new here, been looking at this mod for awhile and i just left my dealership ordering the parts to do the swap on my 14 seems everyone has done the swap on the 16 up front ends so i guess ill be the first for the 14-15 parts will be in tom and gonna drop the hood off to my paint guy hoping itll be paint by this weekend ill keep you guys posted
10 minutes ago, Kelvin Thomas said:
I need help doing this on 2017 gmc what all do I need and who paints the hood or is it already painted
Uh did you not read the very first post that has everything you need with the part numbers??
Just painted mine Friday,  hopefully we will have it on next week. We are doing the ram air box too that the hood lines up with.
On 3/24/2019 at 4:06 PM, Mikegriff01 said:
2500 ram air box mated to stock intake .
This ended up not working we used a k&n cold air intake tube and just trimmed it to fit the ram air box
On 3/28/2019 at 4:21 PM, Blk99cobra said:
Took a lil longer that i thought painter got slammed and had to work me in
Did you do the 2500 front end conversion or did you already have a 2500 but added the newer headlights?
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
