On 4/5/2019 at 3:23 PM, Mikegriff01 said:
This is how I ended up doing the air box
Old thread, I know...this thread and mod is worth its resurrection.
Dude, it looks like you bridged the gap with a rag. What the hell is that?
Nice truck btw ?
  • 4 months later...
On 3/11/2017 at 10:07 AM, 14GMC14 said:
I mainly did it just for looks but I am sure it should help the engine get more air and more power. I don't have any pictures of mine from under the hood but this is what it looks like under the insulator.
Do you know what those bolts bolt into? I thought I had everything and I see there’s nothing to fasten the bolt into. I took a picture from my install and circled them red.  Please help!! 🙏😅😅
On 6/5/2019 at 12:30 PM, Mikegriff01 said:
You wont need the grill or the bumper. You'll need the hood and the hinges and springs at the bare minimum.  The intake duct work, the hood vent, all of the clips associated with it. I dont have my parts list but lots of guys on here do.
I have some questions on the intake install. Do you have Instagram or something that I can connect with you?
I’m having the same issue go to advance or any parts store and get the license plate kit it comes with clips that go into the hood where the holes are and the bolts that attach to it you will also need to get some washers for it to hold the bolt in
I am in the same boat. I ordered the parts (or in some cases the replacement parts as some have been replaced by GM) from the original post. The online GM parts store I ordered them from didn't send the (6) Insulator Retainer Part Number: 11571159 which I think are push in plastic retainers for attaching the underhood insulation pad. However I need (8) of them if this is correct. Also I have nothing to go in the square holes nore the bolts to mount the underhood air duct to whatever goes in these square holes. I think they are supposed to be (8) metal clip but can anyone confirm? I don't trust the plastic license plate pop-ins given the amount of weight and that it's suspended.
I think I found the correct part, part number is 11547582
On 3/10/2017 at 3:41 PM, 14GMC14 said:
Just finished my HD hood install on my 2016 GMC And I would like to share the part numbers and information for anyone that would like to do the same. This should be the same for 2014 and up. For Silverados
I think the same parts are required just different part numbers.
Parts:
Nut
Part Number: 11546860 $2.31 × 4 $9.24
Assist Spring, RIGHT
Part Number: 23258272 $17.24 × 1 $17.24
Insulator Retainer
Part Number: 11571159 $2.84 × 6 $17.04
Insulator
Part Number: 84101780 $63.22 × 1 $63.22
Duct
Part Number: 84167144 $211.30 × 1 $211.30
Hood
Part Number: 84152916 $385.56 × 1 $385.56
Vent
Part Number: 84183578 $105.49 × 1 $105.49
Spring
Part Number: 23258271 $17.79 × 1 $17.79
Hinge
Part Number: 84097791 $27.83 × 1 $27.83
Hinge
Part Number: 84097792 $27.83 × 1 $27.83
* Subtotal Amount: $882.54
Prices based on GMDirect
Several years has gone by about this swap and this conversation is too long to read lol. Simply, are any of these part numbers current to any online gm part website OR/AND if any of these parts list are excluded for 2014 GMC Sierra 1500. I'm looking for a pre painted black hood and chrome vent, but cant seem to find it in the descriptions.
  • 6 months later...
So was it determined if u need a new cable and hood latch?
  • 5 months later...
I installed a fiberglass ram air hood on my 2017 Silverado and after a year the stock springs will no longer hold the hood up. Is it doable to use the 2500 springs with the 1500 hood hinges?
  • 11 months later...
  • 3 months later...
Parts:
Nut
Insulator Retainer
Insulator
Duct
Hood
Vent
Spring
Hinge
Hinge
Does it have the vent tube that feeds the air box like the fiberglass hoods?
I did this back in 21 and recently tried hooking up the air box and am getting MAF P0101 CEL errors upon full throttle. Anyone in this thread have any advice on how to remedy this?
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,507 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
