Which borla exhaust configuration should I get???
I am wanting to get a OEM GM Borla Cat Back system for my 2017 Silverado. I do not want the "out the back pipes" but not sure if I should go with both pipes out the side or duals out the side
Which do you suggest and why?
Thanks
I personally am a fan of the dual passenger side exit Corsa tips moreso than the Borla, but to each his own. Not sure if there's much advantage to buying the GM variant of the Borla, as you're only getting the backpressure valve included. I have not noticed much of a sound/drone difference between Borla and GM's variant.
I agree with the Borla vs. GM Borla. I went with a non-GM S-Type Borla system and love it/had plenty of compliments. Don't notice any drone but sounds much better than factory.
You should try deleting the muffler first. I paid like 40 bucks. I left the flapper in place. I can have less noise or more noise. It sounds as good or better than the cat back I had on my 2013.
I like out the passenger side, but I couldn't stomach the price so I dejected my muffler. If I ever want a different sound I'll add an xr-1 in front of the flapper valve. I could do that, and buy a soar stock exhaust for a ton less than the GM borla. But the GM borla does sound good, and it's a higher grade of stainless.
Has anyone ran their truck on the dyno after muffler delete?
Not sure, but I remember seeing a dyno result of a Corsa equipped truck. It picked up 12 whp at around 5600 rpm with no tuning. I can imagine the same can be said for the Borla. However, it's hard to believe that a muffler delete would yield any horsepower at all on these trucks.
My thoughts exactly. I know what the Borla dynos but I am concerned that there might even be a slight loss with muffler delete
I purchased the dual out the back exhaust and I regret it. It has been 1 year since it was installed. I drove up a steep incline and the pipes hit dirt. Out the back right wheel (passenger side) is where it's at. It's like a truck should be. I think I will switch to this one. Here is the model number 140550.
If there is a slight loss my butt can't feel it. It feels exactly the same.
The one benefit of dual out back is it keeps the muffler tips from getting pounded with rocks and mud. But yeah you loose a little ground clearance on the rear bumper.
Sent from my SM-G930V using Tapatalk
I'd get the one that has both pipes out the same side.. I feel like getting the duals to match 100% is such a pain in the ass.
  • 4 weeks later...
    Afennell19
    Afennell19
  • Who's Online   2 Members, 0 Anonymous, 955 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
