External HD setup question
Hey everyone. Back when I had my Ford there was a way to connect an external HD to the back of the head unit and I ran the cord to my center console or glovebox. Is there anyway to do something like this in our trucks? TIA.
Do you have any USB inputs? You can use that to connect one. I believe you need to format it to FAT32 and it can't have any type of security software on it.
I ended up just getting a small micro usb flash drive that i keep plugged into a usb port in the center console.
Thanks. I'm an idiot and didn't even realize I had 2 more ports in the center console. I just hate seeing wires everywhere that's why I didn't want to use the dash one.
I would just opt for a micro usb flash drive.
This is the one I went with. If you watch Amazon deals or Fatwallet, it can go on sale for cheaper. I got it for $14.
https://www.amazon.com/SanDisk-Ultra-SDCZ43-064G-GAM46-Newest-Version/dp/B01BGTG3JA/ref=sr_1_1?ie=UTF8&qid=1490108536&sr=8-1&keywords=SanDisk+Ultra+Fit+64GB+USB+3.0+Flash+Drive
I loaded all my music on it and keep it plugged in under the console.
Oh nice. Really tiny. Appreciate the link
Those little flash drives are great. I have four of them and never had a single issue. Search around and you can find better pricing than amazon too. I usually pick up the 32GB model for $5.99 at Bestbuy.
Sent from my SM-G930V using Tapatalk
Looks like they have a 128g version. Will a 2014 support this? I am currently using my iPod Classic 128g for my music. This would be great as I currently have about 90g of music.
Ok... That's impressive.
I just put on random and let it play. I have about 300 or so cds and I rip as high as iTunes will let me. There are also a bunch of mp3 that are at a higher bit rate and you can tell the difference.
I have a 1TB external Hard in my center console. No issues. Plus the power to the USB goes out after a set time. So I don't have to worry about unplugging it every single time.
  • 4 months later...
I have the same setup. 2016 Sierra Texas Edition. I have a problem with multiple copies of the same some showing. I have scoured the whole hard drive. I know for a fact that I only have one copy of these songs. Why do multiple copies show?
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
